How to Remove Interior Dome Lights.
Ive gotten all the other lights replaced with cool white LEDS but i cannot figure out how the hell to get the interior dome light covers removed? I have an 06 TL all help would be appreciated thanks!
in the rear..stick a flat head screwdriver in between both of them and kind of push one way. one will pop out and then the other is easy. basically the same idea for the front except you want to wedge the screw driver in the back (towards the trunk) of the car. these are probably the easiest to replace. hope this helps
the hardest was the damn liscence plate lights. Those are not made to be an easy install whatsoever. First one took me 30+ minutes. 2nd one took about 5 once i figured the best way to do it.
BoricuaTL
04-08-2016 01:08 PM
09-17-2015 09:01 PM
