How-To: Remove carpet/interior
So I just picked up an '06 TL 2 days ago with 19k on the clock. Got a deal I couldn't pass up. Carpet is a bit dingy so I figured I would just go ahead and replace it. I looked around a bit and couldn't find a how to on removing carpet so I made my own...here goes:
The patient:
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130110_171730.jpg)
Start by removing front seats. 4 bolts on each. No pics for that as I think most everyone is able to locate the bolts and remove seats.
The passenger seat belt is attached to the seat (driver side is not) remove cover
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_111804-1.jpg)
next press this little peg to release the seat belt
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_111639.jpg)
belt released
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_111652-1.jpg)
Rear Seat bottom:
Pull the release that is located in the center of each seat. If you were sitting in the rear seat it would be right between your legs. There are 2 of these releases. One on each side
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_112110-1.jpg)
A little bit better shot with seat cushion released
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_112057-1.jpg)
Next unbolt 1 bolt at the back of the seat cushion and you can remove it (on the passenger side)
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_112207-1.jpg)
On to the backrest:
Remove headrests and remove 2 bolts one on each side in this location
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_120430.jpg)
Finally remove 2 bolts at the bottom of the back rest on each edge toward the door. I forgot to take a picture here, but you can't miss it. Then unbolt seatbelts and leave them up in the rear window
Next up interior trim:
Remove Fusebox trim. Carefully pry it loose. It;s only held on by x-mas tree clips
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_114431-1.jpg)
If you're not sure what the clips look like
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_114440-1.jpg)
work your way down each side by removing driver doorsil trim then lower b-pillar trim, rear passenger doorsil trim and finally the most rearward trim next to rearseat cushion. All are held on by x-mas tree clips. Repeat on other side
driver doorsil
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_114515-1.jpg)
Lower B-pillar
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_114559-1.jpg)
rear driver side doorsil
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_114619-1.jpg)
and lastly the seat trim (the rearmost piece)for lack of a better description
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_121638-1.jpg)
Center console:
Start by removing these 2 screws on each side (4 total)
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_123403-1.jpg)
2 more screws in the console cubby under the rubber piece
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_122927-1.jpg)
Next remove the metal trim pieces on each side of the console. Carefully pry them loose. They are held in by metal clips
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_125024.jpg)
Clips look like this
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_125044.jpg)
Next unscrew the shift handle...it simply twists off
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_114740.jpg)
Remove cupholder, forgot pics here. But pretty selfexplanatory
Remove these 2 screws on each side (4 total) and you should be able to slide the rear portion of the consle after you unplug connections
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_125529-1.jpg)
Next remove the bottom cover under the steering wheel. Again, these are held on by metal clips so gently pulling will release. There is one plastic clip here you need to remove
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_130657.jpg)
Move over to the passenger side and remove glove box by gently pulling on each corner
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_133048.jpg)
and the other corner
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_133059.jpg)
gently push this plastic bracket and it will release
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_133142.jpg)
and finally remove 2 bolts (1 on each side) and set the glove box aside
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_133233.jpg)
Remove the trim piece behind the glove box. Held on by 2 screws. Here's one, you'll see the other
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_133250.jpg)
then push the center of this clip in (2 total) and pull out
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_132952.jpg)
Gently pull and metal clips will release
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_134207.jpg)
Next remove the side console trim piece on driver side or passenger. There are 3 screw and metal clips. Remove the screws and gently pry the piece off. Repeat for passenger side
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_131531.jpg)
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_130303.jpg)
Next remove the trim ring around the shifter
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_135444.jpg)
remove 2 screws and you can remove this part of the console. Gently pull back and up and it will release. Disconnect plugs
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_135239.jpg)
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_140327.jpg)
Almost there. Next release the gas pedal. There is a little pushclip in the back of the gas pedal at the bottom. Push it in and lift pedal straight up. Hopefully you can tell in this shot what the clip looks like
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_114728-1.jpg)
Next remove foot rest, dead pedal or whatever you like to call it.
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_114651-1.jpg)
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_114702-1.jpg)
Next remove this bolt and the 2 other bolts holding this bracket. You can see one of the bolts in the background
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_141935-1.jpg)
Next remove 4 bolts that is holding the shifter in place. 2 in the back and 2 in the front
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_141106-1.jpg)
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_141921-1.jpg)
Now you should be able to lift the shifter assembly out of the way and remove carpet.
![](http://i568.photobucket.com/albums/ss124/mille_3/06%20acura%20tl/20130112_142310-1.jpg)
You can go a step further and disconnect linkage and remove handbrake, but since my carpet is trash. I just decided to cut slits in it and slide it around the handbrake....That's it.
Hopefully someone can find this guide useful.
The patient:
belt released
Rear Seat bottom:
On to the backrest:
driver doorsil
Lower B-pillar
Center console:
hondeducation (11-22-2016)
How come the carpet is trashed at only 19k miles? :/
New carpets were about $300. But that's not the point. Of course if I wanted to pinch pennies I could have done any number of things and still had sand and other funky smells in that carpet. I really dont know how he managed to get the carpet so filthy when the rest of the car is pristine.
Besides I'm ripping out all the sound deadening material and laying down a combo of fatmat/acoustic foam to quiet down the ride and keep the music in the car. Nothing screams rice as when someone pulls up next to you and all you hear is heavy base and crazy rattle.
Received 6,470 Likes
Very well done write-up.
just make sure you re-thread those upper bolts in partially behind the headrests before trying to install the rear seatback. They did not need to be removed completely.
^Order from any one of the OEM forum vendors. Last I looked they were about what he said, $117 each for the front and back.
They are listed in the "Floor Mat" section.
I too plan on going with a different color. I want to replace my grey with black.
hey mille_3,
if you cut your old carpet and slid it around the hand brake, how did you put in the replacement carpet without removing the handbrake? but awesome thread! im glad i stumbled across this because i really need to replace my carpet. now i have the motivation and ill be able to run my speaker wire under the carpet instead of it hanging out around the center console.
hey mille_3,
awww, no "Dynamat" ?
Hey guys I was curious to know where you purchased your replacement carpet from. I was planning on Rosing mine from Honda parts unlimited. But then I went to checkout it said that shipping was $190! That's ridiculous. That's more than half the cost of the replacement carpet.
your how-to saved me a headache from figuring out how to remove that damn gas pedal! that was the last step I was missing, until I found your thread. thanks for sharing, and i hope the car has been treating you well!
justnspace (11-22-2016)
Excellent write up bro. Our TL just hit 110k and we've sprung for new leather for the front seats and console. Plan on doing the seats in a few months when the weather is warmer so will look at replacing carpet as well. Maybe cleaning depending on cost. Thanks for the pics and step-by-step.
dainmezron
10-16-2015 06:56 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
