How to program key FOB
Old Oct 27, 2006 | 08:42 PM
Dusky's Avatar
Hello guys, I bought key fob's (M1 & M2) from ebay, can someone tell me how to program them for my 04 TL. I tried to find any similar thread in index but no luck. Any help appreciated.
Old Oct 27, 2006 | 10:19 PM
dmarcus48's Avatar
Good old search function:
The keyfob is #16 in this picture. The cost shown is list $78.27, discount price $66.53
http://www.acuraparts247.com/sunnys...=All&vinsrch=no
You can ask the service manager if he will charge you anything if you buy the keyfob from the dealer.
If he wants too much, or if you want to do it yourself, you can follow these instructions.
PROGRAMMING THE REMOTE TRANSMITTER (KEYFOB)
Storing transmitter codes.
The codes of up to three transmitters can be stored into the keyless receiver unit memory. (If a fourth code is stored, the code which was first input will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors, the hood and the trunk lid are closed.
1. Turn the ignition switch ON (II)
2. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
3. Within 1 to 4 seconds, turn the ignition switch OFF.
4. Within 1 to 4 seconds, turn the ignition switch ON (II).
5. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
6. Within 1 to 4 seconds, turn the ignition switch OFF.
7. Within 1 to 4 seconds, turn the ignition switch ON (II).
8. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
9. Within 1 to 4 seconds, turn the ignition switch OFF.
10. Within 1 to 4 seconds, turn the ignition switch ON (II).
11. Within 1 to 4 seconds, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the driver’s side of the dashboard.
12. Confirm you can hear the sound of the door lock actuators within 1 to 4 seconds, then push the transmitter lock or unlock button again, or the code will not be stored.
13. Within 10 seconds, aim the transmitter (up to two additional ones) whose codes you want to store in the keyless receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and remove the key.
15. Confirm proper operation with the transmitters.
NOTE: Once the programming mode is entered, the remote button must be pressed a second time. If the button is not pressed, or if the ignition switch is turned OFF, the programming for all remotes will be cancelled.
Old Oct 30, 2006 | 02:34 PM
Dusky's Avatar
Thanks a bunch!
datadr
Mar 23, 2016 01:39 PM
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
malvothegreat
Sep 29, 2015 12:38 AM
