How many times a day do you
Old Apr 6, 2004 | 12:32 PM
Donte99TL's Avatar
Does anyone read this
How many times a day do you bring your car to red line? I do it about 8 times a day. It’s such a rush. Do you think that's to much?
Old Apr 6, 2004 | 12:36 PM
JoganJani's Avatar
never stops!
I'm very tempted to do it but I go till 6000-6500 I do not have redlined once. I'm scared of taking it in redline.
Old Apr 6, 2004 | 12:41 PM
Teh Jatt's Avatar
The Oracle of Acurazine!
I dont do it every day... but in past i've done it 2-3 times... acutally it was right on border line of where redline starts.
Old Apr 6, 2004 | 12:42 PM
MikeyK's Avatar
NBP - Public Relations
:lol2: This car does have a lot of power.
Old Apr 6, 2004 | 01:10 PM
caball88's Avatar
i shift at about 6K most the time if i am reving hard, the car has 1600 miles so i am a little reluctant to take it all the way to red.
Old Apr 6, 2004 | 03:03 PM
Donte99TL's Avatar
6k is pretty high. I don't think an extra 1000 rpms will hurt it
Old Apr 6, 2004 | 03:16 PM
Norse396's Avatar
Taking the engine to redline doesn't help it go faster, the engine makes 270hp at 6,200 rpms so there is deminishing returns on shifting at redline. In fact at times it can hurt your qtr mile run to shift beyond into the red where it strains to maintain power but instead holds you back a little. I shift at 6,700 so I'm higher in the band in the next gear. I hope to find out what sift point works best in the 5AT when we take them to the track.
Old Apr 6, 2004 | 03:35 PM
rynpamn21's Avatar
in the 3 months i've had it i probably did it 2-3 times......you do it everyday? hmmmmwhat MPG do you have?
Old Apr 6, 2004 | 03:38 PM
w1n78's Avatar
100k miles club
the highest i've gone is 5800-6000 and that's shifting 2nd -> 3rd. by then i would've either smoked the person playing w/ me or just wanted the rush i'd probably do twice a day if not less
Old Apr 6, 2004 | 03:57 PM
Donte99TL's Avatar
Norse396 get yo ass to the track mang
rets's Avatar
Moderator Alumnus
Exclamation
Right, it may hurt the engine, but IMO it should help your acceleration if you intend to upshift and keep speeding up in the following gear.
When just playing around the red line RPM ranges, it really waste your fuel and only obtain the declined power, except the loud and roaring engine sound.
However, if you're going to shift it up, for example, from 2nd gear to 3rd gear, the red line in 2nd gear would enhance the initial RPM in 3rd and help your acceleration. My 0.02.
Since having my 04TL in Oct, I only redline once by 2nd gear... so bad... :cop:
Donte99TL, your the man.
Old Apr 6, 2004 | 04:18 PM
vtechbrain's Avatar
Not quite, although no additional power is produced, you will spend additional time at that peak and as long as RPMS are available the car will gather more speed. Therefore you will go faster!
Old Apr 6, 2004 | 04:20 PM
vtechbrain's Avatar
BTW, although your engine is meant to be revved, the more revs the higher the wear.
Old Apr 6, 2004 | 04:27 PM
Whoa... I thought this was a start to a tread I really didn't want to answer..
:o)
If you know what I mean. :piss2: Why doesn't the monkey show up?
Old Apr 6, 2004 | 04:38 PM
WickedWiz's Avatar
Team Nghthwk Whipping Boy
I've actually hit the rev limiter a few times...it's hard to hear the engine with the stereo volume at 35!
I have found that power shifting at about 6000 gives the most kick.
Old Apr 6, 2004 | 04:44 PM
vtechbrain's Avatar
[QUOTE=WickedWiz]I've actually hit the rev limiter a few times...it's hard to hear the engine with the stereo volume at 35!
Ive had the same problem! I wonder when a TSB is comming on making the engine louder so I can hear it over the din of THE WHO at 35!
Old Apr 6, 2004 | 06:16 PM
finishline's Avatar
I was gonna answer once or twice until I saw the end of the question. Instead: never.
Old Apr 6, 2004 | 06:24 PM
Skeedatl's Avatar
Lurker
I pin it pretty much twice a day at least as the freeway onramps I use are pretty short and uphill.
Old Apr 6, 2004 | 06:26 PM
msb2112's Avatar
I'm not a TL owner yet, plan on it in 05, however I've owned two Hondas in my life, a 1987 Civic Hatchback Si for ten years, then a 1997 Prelude Sh till now. I used to rev that modified Civic to redline many times daily for ten years..up to 150,000 miles with no ill effects. A minivan finally killed it by rearending me at a redlight. The first four years of life on my Prelude I used to run it hard...well into redline to just before fuel shutoff or even into fuel shutoff several times per day. I've mellowed out quite a bit since I'm 39 years old now, but as far as the engines being able to take it for many years...I see no problem with that. Granted the TL is a six cylinder and the Civic & Preludes were 4, but Honda/Acura engines are so well built that redlining daily is not a problem for wear. I won't comment on fuel economy and 1/4 mile times, shift points, etc...just the wear issue.
Old Apr 6, 2004 | 06:46 PM
Xpditor's Avatar
Cool What's the point?
Norse: I know that you know this 'cause I read your list of cars you've owned. You can tell a lot from that.
But, you have to look at power and torque curves and apply the known RPM drop between gears to see the best shift point. Sometimes it is better to go past the peak HP curve if the shift drops you into a better fat part of the next gear. (I don't know if I'm making that point clear. It would help if I had an actual graph). For example: if the rev drop is 1,000 RPM between 2nd and 3rd and the motor is still making 250HP at 6,500 RPM (past peak) but a shift at 6,200 RPM would drop the revs to 5,200 where the HP is only 210HP, then you are better off keeping the RPMs higher and going past the peak.
Old Apr 6, 2004 | 06:52 PM
Xpditor's Avatar
Wink Behind Blue Eyes
Did you find The Who on DVD-A??? If so, where??
It's slim pickings for DVD-As where I have looked. Especially for Classic Rock.
"Feed your head; you have no right not to." -Marge the Barge (Don't ask. I was in an altered state of consciousness) :facelick:
Old Apr 6, 2004 | 06:56 PM
Xpditor's Avatar
Yo, Dawg!
Originally Posted by Chuck
How many times a day do you Whoa... I thought this was a start to a tread I really didn't want to answer..:o) If you know what I mean. :piss2: Why doesn't the monkey show up?
:devil: Why, did you have a smilie of a monkey getting spanked??
Actually, I thought it was a dog! In any case, it's fu<ked up! No workee.
mada51589
Jan 9, 2025 04:40 PM
PortlandRL
Sep 14, 2015 12:01 PM
jordanboi
Sep 5, 2015 01:33 AM
