How many grease fittings?
Old Oct 2, 2004 | 11:31 PM
pedalermike's Avatar
Anyone know if there are any grease fittings on the chassis that should be topped up during oil changes? I can't find any info in the field service manual.
Old Oct 2, 2004 | 11:47 PM
Repecat's Avatar
Gratis dictum
I think grease fittings went out with vacuum windshield wipers. Shouldn't be any.
Old Oct 3, 2004 | 05:10 AM
batting_cleanup's Avatar
There are a couple right up front. One on each side of the hand crank for starting the engine
Old Oct 3, 2004 | 08:38 AM
fla-tls's Avatar
On the way!
Yeah - I don't know of any car manufacturer that still uses grease fittings that you can top off. Unfortunately they all use those sealed ones now.
They must be saving $.05 per fitting...
Old Oct 3, 2004 | 08:52 AM
pettydw's Avatar
When was the last time you had to change a tierod end or ball joint on a Honda? I'll bet the answer is never. The cars I've had with greese fittings (non-Hondas) all wore out those components once or twice in 100,000 miles.
Old Oct 3, 2004 | 09:18 AM
ok. You guys are killing me. My last vehicle was a Durango (no flames...), and other than it being a POS, it had 7 fittings that needed topping up. I had to replace the ball joints twice as well as the pitman arm and tie rod ends. So much for a well built American vehicle. TG that I ditched that truck and moved into something more reliable.
So then, if there aren't any fittings, then why would anyone pay more than the price of an oil change for a B service? Those inspections I've seen others list take all of 5 minutes when your under the car or rotating your tires.
Old Oct 3, 2004 | 10:15 AM
Ron A's Avatar
Administrator
That's exactly what a lot of us have been saying, a lot, for a long time, to a lot of people, who get screwed by their dealers into paying more for an A service, or a B service, than what an oil change costs, + maybe a tire rotation if needed.
Old Oct 3, 2004 | 10:44 AM
Well, I'm glad I wasn't missing something. I hate to pay more than I have to but I also don't want to reduce the performance of my car. I keep a ready stock of all the important fluids and can top them up myself.
Old Oct 3, 2004 | 02:40 PM
Road Rage's Avatar
Not a Blowhole
The zerk fittings on SUV's are not there so much for routine service, but to allow the owner to squeeze grease in after the vehicle has been driven in streams or deep puddles - the new grease pushes out any residual water and dirt. Plus, if there are no caps on the fittings, they can allow crud in.
Most mfrs also recommend changing out the diff fluids since water can also get in the vents if deep enough.
Chassis lubes on many Hondas now consist of cleaning the various steering and suspension boots with silicone to keep they flexible. I posted on this at S2KI.COM. I recommend it, and do it annually on all my vehicles (clean, dry, then spray).
Old Oct 4, 2004 | 07:37 AM
TBone2004's Avatar
Team Anthracite Member
Wow - reading this thread brought back so many memories growing up of when my Dad and I would work on the cars. I always remember "greasing the fittings" while doing an oil change. Some of them were a bear to find and then trying to reach with the grease gun. I guess I never thought about doing it on the new car - glad I read this first before I started looking for them.
SidhuSaaB
May 30, 2020 12:40 AM
vpasla1
Sep 17, 2016 07:24 PM
Avenger411
Oct 11, 2015 03:53 PM
ROWDY621
Sep 30, 2015 03:20 PM
Bielikb96
Sep 28, 2015 10:45 AM
