How to change 2005 TL door light??
Welcome to AZ Like mentioned above, just pry it up. It's very easy. Test the bulb before you put the light cover back on. Don't forget LED's current only travels one way, so you must have the LED in correctly. Which is why you want to test it before closing everything up. Good luck and have fun......
are you talking about the one at the bottom corner, or the blinky security LED near the lock? the bottom one is easy and instructions are listed above...actually, of all lights in the TL this is probably the easiest to get to. the cover pops off very easy. just go slow and try to find the one or two or three little notches that hold it on.
if you are talking about the red LED then thats a different story...
mada51589
05-03-2022 08:54 PM
handsom-hustla
11-13-2015 05:04 PM
ahsm
09-09-2015 08:35 AM
drewdeezy03
09-03-2015 08:04 PM
