HID's
Old Sep 1, 2012 | 05:36 AM
Phambam12's Avatar
Phmbm12
HID's
My HIDs went out and its not the bulb. im assuming its the igniter but igniters are expensive.
so i was wondering if i could just buy an HID kit from ddmtuning and just replace the entire thing.
which kit would i buy? the D2S one? has anyone else done this? or did you guys just buy a new igniter?
Old Sep 1, 2012 | 06:27 AM
truonghthe's Avatar
^^^which HID are you talking about? Headlight?
if so then I would just buy OEM or from Theretrofitsource.com since they sell Denso, Matsushita and Morimoto which all used by OEM Japanese car and the expectancy life on these thing should be 5 years or more (same as OEM ballast).
Please stay away from that DDM crap the thing already broken once it came in the mail and take two weeks to shipped from China.
You need to get the D2S ballast. OEM cost around $360 for ballast and igniter shipped from Delray Acura, I would recommend you to test to see if its a bad ballast or igniter before ordering, best of luck to you
edited:
or you can go on ebay and buy used parts for less than half of the price.
Old Sep 1, 2012 | 03:20 PM
Phambam12's Avatar
Phmbm12
360?!
Old Sep 1, 2012 | 05:33 PM
splew's Avatar
How did you come to this conclusion?
Old Sep 1, 2012 | 10:11 PM
Phambam12's Avatar
Phmbm12
i bought a second set of bulbs and it doesnt work
Old Sep 1, 2012 | 10:43 PM
EATSLEEPRACE's Avatar
6SPEED FEVER
Just buy a kit from ddm or hid extra....
Old Sep 1, 2012 | 10:58 PM
SpiderX1016's Avatar
I wouldn't cheap out on those kits when the TL HIDs are so awesome.
Old Sep 1, 2012 | 11:50 PM
VanyDotK's Avatar
Maybe it's a good time to look into upgrading to 55w ballast.
Old Sep 2, 2012 | 09:28 AM
nate_0022's Avatar
Land of 10,000 lakes
Here you go.
http://www.theretrofitsource.com/index.php?cPath=26
Old Sep 2, 2012 | 09:51 AM
LockDots's Avatar
Engineer in Training
Here you go
http://www.theretrofitsource.com/pro...ducts_id=12811
Old Sep 2, 2012 | 10:47 AM
The Machine's Avatar
Registered Member
Originally Posted by LockDots
OMG, I want to see these installed, lol! 100W
Old Sep 2, 2012 | 02:27 PM
nate_0022's Avatar
I've seen a pair of 75W ballasts installed in TL's before and they were insanely bright. I couldn't imagine 100W. I would sure hope they are adjustable. I wouldn't think the projectors would be able to handle that heat.
Video:75w watt ballasts in TL's
Pics:
http://www.hidplanet.com/forums/showthread.php?43061-2010-dodge-ram-TLs-75W-denso-clear-TL-lens/page4
Old Sep 2, 2012 | 03:18 PM
splew's Avatar
Oh I see.
Old Sep 3, 2012 | 12:03 PM
sauceja's Avatar
Desert Life Sucks!!
I would think oem as well.
But agreed. Don't cheap out on your main headlights.
Old Sep 6, 2012 | 01:04 AM
Phambam12's Avatar
Phmbm12
I spent so much on tuition so I'm kind of lacking money. I think i'm gonna have to buy a set of DDM HIDS for my main HIDS. anyone have any idea which one i'd need?
Old Sep 6, 2012 | 02:09 AM
MandoTL's Avatar
Just curious OP, before your headlights went out what color did they project. I feel that mine are due for new bulbs and possible igniter. I have seen countless TLs that had a very small hint of blue hue compared to mine that seem to have shifted to white.
I am being lazy to look up threads on the symptoms of the headlight bulbs going out or ignitors or ballasts. I can agree that college tuition is expensive and most of my returned leftover cash paid for books, rent and parking permit.
Old Sep 6, 2012 | 06:55 AM
^an HID bulb that is nearing its last leg would display a pinkish hue.
Old Sep 6, 2012 | 11:56 AM
MandoTL's Avatar
Well from inside the car it looks white with out any kind of hint of blue. But I will look at them tonight and double check to make sure. But since my bulbs are close to 7yrs. old I think they are looking a little pink/whiteish.
My eye sight is a bit bad as far as partially color blind so in fact i will see it as white but it might be pink. I will get a second opinion on color.
Old Sep 6, 2012 | 12:36 PM
thaas407's Avatar
Tos
How do you check to see if its the ballast or the ignitor. My passenger side HID won't come on unless I click on and off about 50 times...and finally it will light and stay lit until I shut the car down. Then if I want it to come back on I do the same thing. The light is still a bright color (no purple in it) so I know the bulb is good. I just don't know if its the ignitor or the ballast or both. Any suggestions would be appreciated.
Old Sep 6, 2012 | 03:33 PM
You swap a good igniter or inverter over. One by one. Like from one side to another but be warned, you can short out the equipment this way.
Old Sep 6, 2012 | 04:15 PM
Phambam12's Avatar
Phmbm12
i dont mind the DDM tuning HIDS. thats what i have for my fog lights. i've been driving around with those on instead.
Old Sep 6, 2012 | 04:16 PM
Phambam12's Avatar
Phmbm12
But of course i want the HIDs to work
Old Sep 6, 2012 | 06:49 PM
350's Avatar
350
My first ricer
If there's a way to make Morimoto ballasts from TRS work I'd go that route, I had their 50 watt ballasts in a retrofit I did and the rocked, I'm sure it's way cheaper than stock too, but I don't know what wiring you would have to do to make non-stock ballasts work.
Old Sep 6, 2012 | 07:40 PM
Will1688's Avatar
if the morimotos are already d2s, you'd just need a hid kit harness to get power from the battery
http://www.ddmtuning.com/Products/HI...Wiring-Harness
if not d2s already you'd need the AMP to D2S connectors aswell
Old Sep 7, 2012 | 09:23 AM
350's Avatar
350
My first ricer
Yeah, I had D2S Morimotos, but I was using them on a vehicle that had factory 9006 so it plugged right in. I just don't know what kind of connector there is going to the factory ballast on our cars, never had a reason to look at it so I don't know if you'd have to splice something get a signal to it. No need for a relay with 35 watt ballasts but for more wattage definately go from the battery.
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
