HID Question. Please Help!
Old Mar 28, 2011 | 10:25 PM
Qhab-Meem's Avatar
So I was thinking about getting some brighter HID's for my TL.
And i was wondering if i would just need to get the HID bulbs or do i need the ballasts too?
Old Mar 29, 2011 | 01:05 AM
Qhab-Meem's Avatar
Help???
Old Mar 29, 2011 | 01:25 AM
TheChamp531's Avatar
Chapter Leader (San Antonio)
Very simple search. :/
You only need HID bulbs. If you want them "brighter" you want to buy Phillips bulbs 85122+ or Phillips Ultinon Bulbs. Higher lumens - the brighter
Old Mar 29, 2011 | 07:30 AM
nate_0022's Avatar
Land of 10,000 lakes
Osram 66240 CBI if you have an open wallet and they run at 5K with the most LUMEN output on the market right now,they run around $200 a pair. or you can get Philips 85122+, they run at $95 a pair but the output has a tinge of yellow. Or you could try getting 50watt ballasts and 50watt bulbs.
Bulbs:
http://www.theretrofitsource.com/product_info.php?products_id=240&osCsid=onijplof9c k0jkr8pplnbik7hb6gki60
Ballasts:
http://www.theretrofitsource.com/product_info.php?products_id=163
You may want to do some research at http://www.hidplanet.com/forums/ on this set up before considering it. I haven't done any research myslef, but I've heard running this set up gets pretty hot inside the projectors and may cause burning on the bowls, or sometimes even, melting.
Also, don't get this confused. The higher the "K" (Kelvin) rating, doesn't mean they're going to be "brighter" they'll actually be more dim than anything. 4300K is the optimal "K" rating as far as LUMENS go, but Osram has engineered a bulb to run at a 5K rating with the most lumen output and a pure white bulb (Osram 66240 CBI as posted above). So what I'm trying to say is don't buy 10,000K bulbs and expect a "tubular" output.
Old Mar 29, 2011 | 10:14 AM
Qhab-Meem's Avatar
So is the stock HID headlights 4300K
I was thinking about the 6 or 8K?
What do you guys think?
Old Mar 29, 2011 | 11:46 AM
nate_0022's Avatar
Stock are 4300K BRAND NEW, they color shift after minimal use to about 5000K or so. Like I said earlier, if you want "bright" HID's stay away from the higher "K" ratings.
Check my transformation thread, I have pics of the Osram 66240 CBI's. That's what I'm currently running, my avatar pic is with the CBI's as well.
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
