CV joint DIY?
Old Nov 28, 2010 | 11:35 PM
qurious9ss's Avatar
CV joint DIY?
Has anyone in here done the CV joints yet? Searched for a DIY and couldn't find one. Anyways, if anyone has done them, is it a pretty straight forward job or is there something I should watch out for?
Old Nov 29, 2010 | 07:09 AM
Turbonut's Avatar
If the joints are bad, you're better off doing an axle replacement. Joint replacement isn't difficult, just time consuming and special pliers are needed for the clamps.
Old Nov 29, 2010 | 08:35 AM
mn2trance's Avatar
All About Trance
Do you have an AT or MT? If it's AT, your parts will be a lot cheaper if you were to purchase a new transaxle. I bought one for $70 for the passenger side once mine had gone bad. And since I have a MT, I had a place rebuild my driver side transaxle.
Old Nov 29, 2010 | 05:38 PM
qurious9ss's Avatar
Yeah axles are relatively cheap at Napa $90 as apposed to $250 OEMs so will definitely go with the axles, thanks. I have an AT so parts are cheap. I've done a couple of jobs where I have had issues with the ball joints. How difficult is it to pull ball joints on TLs? Will the pitman ball joint puller from autozone work on these?
Old Mar 28, 2011 | 10:29 PM
SurfingScotty's Avatar
2007 6SMT Type-S
How do you know if you have bad CV Joint VS Ball Joint? Does replacing the trans axle replace both? Not too familiar with axles and suspension, can you tell?
Old Mar 29, 2011 | 06:05 AM
Turbonut's Avatar
Just start browsing the web for information and pick up an inexpensive auto repair manual.
You'll need to start doing some research on the subject, but a quick search:
http://www.google.com/imgres?imgurl=...KfO60QGXndzNBw
http://www.google.com/imgres?imgurl=...KeWV0QGesqzNBw
Lower ball joint
http://www.performatek.com/Alfa/Susp...ll%20Joint.jpg
This will show the location in relationship to the drive axles:
http://www.google.com/imgres?imgurl=...GqWU0QGa44mLCA
Old Mar 29, 2011 | 12:21 PM
2007 6SMT Type-S
Thanks, Turbo!!!
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
Brandle34
Sep 23, 2015 07:20 PM
scionxb3003
Sep 22, 2015 05:28 PM
0opie
Sep 22, 2015 04:15 PM
