HID question
Old Oct 12, 2005 | 08:02 PM
mlody's Avatar
HID question
I searched but i could not find an answer. Does anyone know for how long HID bulbs last in our cars?
Old Oct 12, 2005 | 08:05 PM
rbf351's Avatar
Registered User
there is no real answer, but they are supposed to last longer than halogen bulbs
sometimes they can last years, and in a rare case less than a year
Old Oct 12, 2005 | 08:07 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
I think I read somewhere that they can have a long life, but that life is dramatically shortened by flashing them such that they don't fully heat up when turned on and off. In other words, if you're going to turn them on, leave them on long enough to heat up. I'm guessing that would be about 10 seconds or so.
Old Oct 12, 2005 | 08:35 PM
znorris's Avatar
IT OWNS
I can't give you a estimated time, but what I can say is that during the installation of the lights, if they were touched at any one time it greatly decreases the its life potential. The oils on the human skin do not react properly with the filament within our HIDS. Over time, it will eventually take it's took on your lights and you will be forced to replace it. Properly installed, the lights should last for the life of the car....
Old Oct 12, 2005 | 08:37 PM
invincible569's Avatar
What color Kelvin Temp is stock on the HID's?
Old Oct 12, 2005 | 09:39 PM
SouthernBoy's Avatar
Registered Member
This is more the case with a hi-output incandescent such as halogen than with a gaseous discharge lamp such as HID.
HID's do not have filaments in the normal sense.. not like an incandescent.
Old Oct 12, 2005 | 09:40 PM
Registered Member
Figure in the neighborhood of 8000 - 9000 hours.
Old Oct 12, 2005 | 09:42 PM
Registered Member
This is bad for any lamp, be it incandescent or otherwise. However, with an HID, it's worse on the ballasts than the lamp. Best not to flash them at all.
Doing this with incandescents causes tungsten boil-off.
Old Oct 12, 2005 | 10:31 PM
Actuary's Avatar
18,000mi. 29000km
one of reason to stay away from flashing at traffic.
Old Oct 13, 2005 | 12:42 AM
Raheel's Avatar
I believe all Cars have 4200K Stock, and I believe I have read that HID's last the life of the car if not longer, but who knows
Old Oct 13, 2005 | 01:16 AM
I1Money's Avatar
You just dissappointed some female TL fans...
Old Oct 13, 2005 | 02:42 AM
surebob's Avatar
7th Gear
dont the high beams and low beams use the same bulb? and when the high beams are turned on, all it does is shift some reflector inside the headlight to shine higher so wouldnt it be ok to flash someone and not have it affect the life of the bulbs?
Old Oct 13, 2005 | 06:37 AM
Thanks.. I've noticed that the TL's, S2000's, BMW's and some others look more blue than some of the other HID cars. Maybe its the projector lights?
Old Oct 13, 2005 | 06:56 AM
JohnDoe2's Avatar
Yes.
Old Oct 13, 2005 | 06:58 AM
JohnDoe2's Avatar
If you are REAL retentive, you may want to put it up on "blocks" to avoid the flat spotting problem.
Old Oct 13, 2005 | 12:36 PM
Raheel's Avatar
Ya its the projector and how the housing is made
Old Oct 13, 2005 | 01:17 PM
Thanks. I love the sparkle it emitts.
Old Oct 13, 2005 | 07:41 PM
mlody's Avatar
thanks guys for all the answers and good info
Old Oct 13, 2005 | 08:47 PM
Actuary's Avatar
18,000mi. 29000km
Yes only at night. Not during the day.
Old Oct 13, 2005 | 09:00 PM
DonPunani's Avatar
...if they were touched at any one time it greatly decreases the its life potential. The oils on the human skin do not react properly with the filament within our HIDS. Over time, it will eventually take it's took on your lights and you will be forced to replace it. Properly installed, the lights should last for the life of the car....
That's actually incorrect...as mentioned above, HID bulbs have no filament. The main point though is that the oils on your skin don't "react" with the filament in a halogen bulb, per se. The oil from your fingerprint literally creates a hot spot on the bulb and will cause premature failure (glass cracks/breaks). This will usually happen within a few hours, but higher powered bulbs (500W halogens in floodlights) will literally explode within a minute or two of use. Whenever installing these bulbs, use a cloth or towel with a little bit of alcohol and wipe down the bulb after installing...those suckers aren't cheap
Old Oct 13, 2005 | 09:04 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
HID bulbs have a lifespan of about 3000 hours officially.
This is normally considered "life of car" as most people don't do 3000 hours of night driving. That's 165,000 miles of driving at night, or driving with the lights on.
EX: Kris from the 2nd gen forum, our resident tranny expert, has something like 188,000 miles on his 2000 TL and the lights are the factory originals, they've never needed replacement.
But all cars are different, there are exceptions.
Old Oct 13, 2005 | 09:21 PM
bluenoise's Avatar
The USA version of the TL doesn't have the DRLs, so I think he's referring to the projectors. The projectors each have one HID bulb and a shutter to switch between high and low beam.
Old Oct 13, 2005 | 09:51 PM
Actuary's Avatar
18,000mi. 29000km
I believe we are both on right track I think I just need to rephrase my post on top.
If you start flashing at cars during the day, you are rapidly igniting HIDs without time to heatup/cool down. There is a time that's recommended before re-igniting HID. Im not sure what that exact number is (someone said 10 seconds). As a result, you are decreasing lamp life.
Old Oct 14, 2005 | 12:59 PM
Thorin78's Avatar
Previous Owner
If I remember correctly, our lamp/bulb doesn't light more if you go to highbeam. There is a shutter or flap that covers part of the light and that's what causes the straight line. So hence our bulbs should only be at a constant temp all the time when lit.
Old Oct 14, 2005 | 05:31 PM
Actuary's Avatar
18,000mi. 29000km
Which I feel crappy because some cars (I beleive STS) have two bulbs to make twice the amount of light in high beam
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
