HID bulb replacement w/o removing bumper?
I just recently cleared and blacked out my headlights but didn't have my new hid bulbs in time for the reinstall.
I want to know if anyone has had success changing out the bulbs without removing the bumper and the headlight assemblies. I really, really don't want to go through all of that just to replace the bulbs. ugh. I searched the forums with no luck finding anyone mentioning this.
I'm pretty sure the passenger side should be easy, it's the driver side I'm worried about. Not sure if I will be able to squeeze my hands in there.
Anyone?!!! Please advise.
There was a thread a while ago with someone doing it in the wheel well area but that also requires using a torq screw or some star shape screw to unscrew the cap out and then you can switch bulbs. But dude you know what bolts you have to unbolt to get to the lights. So just save you the trouble and take the bumper out and switch them. Plus you do not want to put any scratches on the bulb itself!!
if i ever need to change another HID bulb in my car, ill probably just take off the bumper
https://acurazine.com/forums/3g-tl-2004-2008-93/diy-hid-bulb-change-w-o-bumper-removal-3g-garage-g-004-a-598853/
This DIY works great, your hand will get a little cut up, and manuevering inside without "seeing" is difficult... it would probably take the same amount of time as removing the bumper.. and if you leave the bumper on, and start sticking your hand in the hole with the bulb in it, you run the chance of accidently touching the bulb, or breaking it....
my
It's defiantely possible without having to drop the bumper, but like mentioned the driver side is a pain in the ass trying to get your hand to fit. I'd just say spend the extra couple of minutes and drop the bumper and then install the lights.
