HID Bulb Change
HID Bulb Change
I was just wondering if there was a way to change the headlight bulbs on a 06 TL without removing the front bumper. I have a set of 6000K bulbs that I would ike to put in
He's right. Check out the 3G Garage for more info
G-055: Headlight replacement
https://acurazine.com/forums/car-parts-sale-361/fs-stock-99-2-3-cl-parts-108963/
https://acurazine.com/forums/showthread.php?t=127531
Gordon,
You don't need to remove the bumper at all. You just need to loosen the front portion of the wheelwell covers (turn the wheel away fromthe side you are working on to give you more space) and you'll be able to reach in there to get to the headlight bulb covers. Hardest part is loosening the torx screw that secures each hid bulb cover. You don't even need a torx screw...just use a small flathead that fits within the "star" pattern and that will get it loose enough to unscrew by hand. I'll try to post my 8000k bulb install pics soon so you know what I'm talking about.
Originally Posted by rbf351
he is asking about changing the bulbs, not the housings
so to answer your question, no you do not need to remove the bumper for bulb replacement
G-007: Removal of HID bulbs
https://acurazine.com/forums/showthread.php?t=95400
9.5+10.5 22m=Hella Flush
Registered User
Originally Posted by Ron A
Sorry, I meant to post this link, which also says you need to remove the bumper. If soneone can show how to do it without removing the bumper, that would be great.
the worst part is removing the saftey cover, once that is off it takes less than a minute to swap out bulbs
Here's the DIY posted for HID bulb change w/o bumper removal...sorry mods if I stuck this thread in the wrong place!
https://acurazine.com/forums/showthread.php?t=139313
OH yeah...remember whoever is going to do this mod to take pictures (not only before and after, but left to right stock vs aftermarket) for a comparison so other members know what color the bulbs come out compared to the stock 4300's. Hope my DIY helps...
'08 MX5 GT 6spd.
Im not sure how much diff. the projector makes the output color, but here is my 4300k (stock) to 6000k (Phillips Ulitinon) upgrade. The upgraded pic is a bit over exposed, so the differences are magnified. As far as light output, the untrained eye will not see any less light, just a color change.
Stock
Upgraded.
Stock
Upgraded.
'08 MX5 GT 6spd.
It changes the color enough to set you apart from every other 3rd gen TL (or any other car with HID's) out there but not enough to get you pulled over. The look of 6000ks looks SO much nicer than stock.
B A N N E D
Under good weather condition, 6000k usually provide a better visibility because all road signs or anything white reflect brighter. However when it's raining, you can't see a thing with the 6000k.
'08 MX5 GT 6spd.
Im assuming you dont have them. The light color is not enough to drastically change rain driving, this is a common assumption.
I notice NO different situtions with mine.
acura-cl.com OG
NOTE: i have an 06 TL and when i did my projector mod, the screw is NOT a standard torx bolt. It had a post in the center and would require a special tip to easily remove the screw. I had to carefully work at it with a small flathead screwdriver and would NEVER have been able to do this through the fenderliner.
Maybe this was changed for 06, but it would have been nearly impossible for me to remover the rear headligh cap/cover.
BoricuaTL
04-08-2016 01:08 PM
