Help with wiring led strips
now i know that if i wire em to my park lights that they will stay on ,
but if i wire em to my drls, they will be on with no side marker like , but turn off once i turn the lights on ,
i want them on when everything is off(wired to drls), and i want them on when everything is on (park lights)
can i wire them to both positiers, of will the circut give power to the other line ex turn the parklights on , cause power is spliced togeather
please do not flame me for not searching hahahaha i did a little bit
Wants a TL. Stuck with a
It would be tricky. Because say when your DRLs are off and your parking lights are on, the power from the parking lights would jump through the side marker wiring and into the DRLs. I'm sure there's a way around it bit I'm willing to bet it's complicated.
Question: When the TL's DRLs are on during the day, and you turn on the parking lights, do the DRLs go off?
I have mine wired to the power wire of the wiper blade motors...which is on whenever the car is on....
it is located in a insulated tube going onto the firewall on the driverside...i believe by the brake fluid reservior....it is green
Thanks. That means that it could be wired to the parking lights too, you could just always leave them on.
BANNED
this is how i did my headlights. one rocker switch for angel eyes and one rocker switch for LED strip.
you don't want to have these LED strips on ALL the time, you'll just burn them out faster. what's the point of going thru the hassle of installing/wiring/splicing if they won't give you a long life span?
Land of 10,000 lakes
^def the best way to do this. that way you can control them with a flip of a switch. whenever you want them on...turn them on. whenever you want them off...just don't turn them on.
BANNED
no relay is needed. i just got an illuminated rocker switch from radio shack. switch has 3 prongs on the back. positive, negative, and ground. wire the + lead from your light bar to the + on the switch. wire the - lead to the - on the switch. then ground the switch to whatever you can find. i just grounded mine to a screw under the dash.
Perhaps this thread will help (or confuse):
https://acurazine.com/forums/3g-tl-2004-2008-93/hid-fog-lights-oem-switch-setup-747560/
BANNED
^ahh sorry. forgot to mention the add-a-fuse needed to power the lights. tap into fuse#32.
here is a crude drawing of my wiring setup.
BANNED
16guage.
you can look in my progress thread to see more pics and what not. page 3-5?
SUPRMN84
10-07-2015 09:46 PM
4drviper
09-23-2015 07:42 PM
