help with TL-S sidemarker on 08 TL
Old Apr 21, 2008 | 09:31 PM
Frankie02's Avatar
DoublYouDP
can someone help me out on how to install Type-S sidemarker ?
Old Apr 21, 2008 | 09:34 PM
Be-in my TL's Avatar
06 WDP / 07 WDP Type-S
There is a DIY somewhere, but you may need to go into the wheel well. unscrew them from the rear, then take them out. There is a spot where it catches.. on the rear of the wheel well. Then youcan pop them out. They are hooked in, so you jus tpress the two ends of the side marker and it pops right out. Oh, by the way, I remember removing mine just pulling from the outside. It came right out, I just use my fingers and forced them out from where the groove is. It doesn't work anymore... It might have been rain that soaked it or something.
Good luck
Old Apr 21, 2008 | 09:42 PM
Frankie02's Avatar
DoublYouDP
hmm i hope that i can pull it out from the outside cuz i don't wanna go thru all that hassle to get to it...
Old Apr 21, 2008 | 09:52 PM
LTxArucAx60's Avatar
F-SPORT
When i installed mine, the passanger side i can just simply pull out from the outside with a little force and it came out, you can try the other with force but it was a pita and i had to go in from the trunk to pop those out.
Old Apr 21, 2008 | 10:00 PM
yisrael42's Avatar
what sidemarker are you guys referring to? Can someone please post a pic.
thanks
Old Apr 21, 2008 | 10:06 PM
Fulani has a TL's Avatar
Frankie - If you are wanting to change out the rears. You have to pull the carpeting on the trunk sides, by removing the panel that fits over the trunk latch, 5 of the screw in hooks for the net, one clip (there are 5 hooks and 1 clip on each side driver and passenger). Once you pull the carpet back, reach in and you will either see it or feel it, there are two tabs one on either side, just push those tabs in and push the side marker out. Once you pull it out, just unhook and plug in the new one, then push it back into the opening. Very simple..
One thing I realized, when placing the Type-S rear sidemarkers into a UA6 the connectors are different, as in the female end which is on the sidemarker is actually bigger than the Male end that is attached to the wiring. So be sure to test them before you push it in.
Old Apr 21, 2008 | 11:29 PM
Frankie02's Avatar
DoublYouDP
Thnx Fulani
MetalGearTypeS
Aug 29, 2016 08:28 PM
Timmy18
Oct 17, 2015 03:58 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
UA7_Ando
Sep 28, 2015 07:53 AM
jmaxima03
Sep 27, 2015 10:22 AM
