help with squeaking tires?
Old Sep 11, 2004 | 05:34 AM
AngryAndy's Avatar
I slap people
hi guys, my front tires are starting to squeak when i step on the brakes.. is there any easy way to fix this? what u guys recommend that i do? help! thnx
Old Sep 11, 2004 | 06:12 AM
nayyarn's Avatar
Desi Pride
Check your tire pressure to begin with.
Old Sep 11, 2004 | 07:34 AM
neuronbob's Avatar
Your tires are squeaking? Are you sure it's not your brakes that are squeaking when you press on the brake pedal? More detail, please, thanks.....
Old Sep 13, 2004 | 07:06 AM
AngryAndy's Avatar
I slap people
yea it is the brakes i believe
Old Sep 13, 2004 | 05:48 PM
xristos's Avatar
.:HALCÓN DE LA NOCHE:.
When was your last brake job?
Old Sep 13, 2004 | 05:54 PM
Road Rage's Avatar
Not a Blowhole
It really helps if you guys can give some 411 for us gearheads when you pose a question as nebulous as "my brakes squeak". This is like headaches, one of the most common complaints people have.
Example: My car's brakes started squeaking after I (did/did not) have the pads replaced.
My car has XXXXXX miles and i drive mostly in stop and go traffic. That sort of thing.
If you do mostly stop and go, my guess would be you have a buildup of outgassed brake volatiles on your rotors. I would find a deserted road and get on the brakes hard a few times, with a cool down in between of a mile or so.
If your pads are fresh, did you break them in properly? 100 miles of general suburban driving to get the "green" out?
If you have a lot of miles, it could be the wear indicators.
If you had the pads replaced, they may have forgotten the shims. Or they did not grease the caliper retaining pins with silicone grease.
Need more info.
jblessing
Aug 8, 2018 09:43 PM
2012wagon
Sep 29, 2015 04:21 PM
njresendez
Sep 21, 2015 11:23 AM
forrie
Sep 15, 2015 09:57 AM
jliu6789
Sep 8, 2015 08:02 PM
