HELP! Doing Headlight Swap, need to know how to remove BACK COVER
Old Dec 8, 2013 | 05:55 PM
Kaiii's Avatar
Wow Amaze Such TL-S
Hi guys,
Trying to swap a headlight right now but i have no idea how to remove the back cover off of my current headlight?? It's a weird hex-shaped nut or something? Wondering if anyone knows how to do this and could help me out asap!!! (running out of daylight)
Old Dec 8, 2013 | 06:23 PM
Acura604's Avatar
2024 RDX A SPEC
Torx set...go get it!
Old Dec 8, 2013 | 08:01 PM
nttstt444's Avatar
The right size flat head will work too if you don't own any torx bits.
Old Dec 8, 2013 | 08:54 PM
Kaiii's Avatar
Wow Amaze Such TL-S
got itttttttttttttttttttt thanks guys
Old Dec 8, 2013 | 09:00 PM
guitarplayer16's Avatar
For future reference, I remember using pliers to EASILY remove it when I couldn't find the torx bit.
Old Dec 8, 2013 | 10:52 PM
Kaiii's Avatar
Wow Amaze Such TL-S
Holy moly. I was taking off the headlight and everything was going swimmingly, until I saw that thing and thought, 'what the heck is that?' the small raised part in the middle especially vexed me.
Luckily I found one of those torx bits in my garage and it fit. I ended up having to use pliers as well, GP - one of the sides wasn't coming off so it was the last resort. When I put them back on, I just made sure the cover was on securely and left those little torx screws off completely...if I ever need to swap out the stock headlight bulb, I NEVER want to have to deal with that again haha.
Thx guys for the incredibly fast advice/solution - got everything done today!
Old Dec 9, 2013 | 02:52 AM
paperboy42190's Avatar
its actually called a security bit, not a torx bit
Old Dec 9, 2013 | 10:13 AM
GKinColo08TL's Avatar
They are also called Torx, my son had a Saab and almost every fastener on the car were Torx. Many of the manufacturers now are going to them.
Old Dec 10, 2013 | 12:02 PM
20_sec.hatch's Avatar
I had to buy a full set for my audi that is almost all they used on the car.
Old Dec 10, 2013 | 02:45 PM
swoosh's Avatar
takin care of Business in
I used a flat head to remove mine....a tiny flat head that is
Old Dec 10, 2013 | 05:16 PM
njkode's Avatar
From what I have seen it's only called a security bit if it has the post in the middle.
Old Dec 10, 2013 | 05:38 PM
ZOMGVTEK's Avatar
The ones with the post in the middle are typically referred to as security Torx, or tamper resistant Torx. Regular Torx are the same, just without the center post. They are fairly common. Usually you can get a Torx out with a flat blade that fits tightly, or grind one down to fit. Thats what the security torx is designed to prevent.
Many other tamper proof fasteners exist, saying 'security' does not say much.
Old Dec 10, 2013 | 11:38 PM
And they are not tamper proof or security if you can go to any auto parts store and buy the set of bits. They are Torx.
Feb 25, 2020 09:57 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
Skirmich
Sep 15, 2015 06:41 PM
