Help diagnosing clicking noise coming from engine. (Video)
So 2 weeks ago I changed the oil and the power steering fluid too because it was making whining noises. I change the o-ring a year ago and that fixed it for a short period of time but the whining noise came back.
Now the engine is making this clicking noise that is probably unrelated to the oil and power steering fluid change but I just thought I would throw it in there for reference.
I checked the oil level and it is in between the lines. I used the same engine oil I have been using for the last 3.5 years of owning this car(pennzoil platinum).
I used the turkey baster method for the power steering fluid change. I put newspaper all around and was very careful not to spill anything.
https://streamable.com/4ljzz
Thanks.
Thanks.
I've seen all fail at some point in time. Rather than worry about the statistical analysis of previous failures as a method of troubleshooting, you should focus on your current situation to determine the failure appropriate to your car.
Thanks.
Thanks.
Now back to the LED conversion on the inside.
03tlCHARCOL
Jan 15, 2010 05:47 PM
Jinro
Jul 16, 2006 11:32 PM
leor
1G CL Photograph Gallery
Oct 3, 2004 08:21 PM
