Help dealership just called! Need hel instantly
SHAWD 04TL is in
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
OK guys seeking advice from the most helpfull people on the planet.
My cars in service & Dealership just called & strongly recomended a FLUID EXCHANGE. They said the trans fluid is dark.
just 2 months ago I did a DRAIN & REFIL...
which I thought was the exac same service, but now they tell me they only drained the 4 quarts that were in the pan... not the full transmission.
my question is,.... is there a diference, or are they telling me somthing.
SHAWD 04TL is in
I know, Its just that Im am too busy at work today.... They are willing to credit what I paid 2 months ago ($89) torward the $219 leaving me with a balance of $130... Is this worth it?
AZ Community Team
Received 7,770 Likes
They are telling you right.
Dealer (or owner) will often do a drain and fill (3 or 4 qts only). Then repeat every now and then.
The other way is a "3 x 3" so-called "flush" where they do the drain and refill three times in a row. This replaces most of the fluid in one service and is recommeded ~60k (iirc) miles. Many here do this every 15k or 30 k miles.
Honestly, the dealer should have done the 3 x 3 the first time or give you credit for what you paid a couple months ago. Basically they are double-dipping a little by doing both services so close together.
If they only drained the first time and didnt do the 3x3 as stated above, make sure they credit you and get the correct service done.
SHAWD 04TL is in
OK called another dealership & they were able to break everything down for me.. seems I could use the full FLUID EXCHANGE. (they actualy hook up a hose & pump new fluid fom one end & drain from another end. to ensure it gets flushed COMPLETELY.... now with that said I think I'm guna do it. My only regret is, they should have recomended this service 2 months ago.
AZ Community Team
Not if you're talking about an Acura and changing transmission fluid. NO!!
Even Acura's Service Manuals and Tech Articles say NO MACHINE FLUSH.
Correct method is drain 3 quarts and refill 3 times. Period.
AND not only should they have recommended it 2 months ago, they should credit you that amount for double-dipping.
SHAWD 04TL is in
SHAWD 04TL is in
No, No, NO!!
Registered but harmless
Received 1,106 Likes
The proper way to change fluid per Acura's Technical Service Bulletins and Manuals is to drain, fill, drive 10 minutes (make sure trans gears all shift), drain, fill, drive, then drain and fill for the 3d time- that's the "3X3" referenced here, in the Acura bulletins and in the 3G Garage here.
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Wait-- here's the Jan. 2008 service article you can print up for them:
http://www.in.honda.com/Rjanisis/pubs/SN/B080100.PDF
SHAWD 04TL is in
You guys are the best, don't know anywhere else you can go to get such FAST & GREAT help. So everythings been finished & Im guna go pick her up after 5pm. Ill let you know how it goes.
They aren't doing the normal flush. They are using the pump with the engine running to push the fluid out while new fluid is being installed. No problem as long as they don't let the trans run dry.
Don't know how many miles on the TL, but the trans fluid is 100K fluid, unless driven hard, then 60K, but my personal opinion is to just do the 3 x 3 wothout the engine/trans operating. Takes longer, but better be safe than sorry.
Chapter Leader (San Antonio)
SHAWD 04TL is in
the trans holds 7.3 qts and a normal drain out gives up only 3.a little quarts at a time.
The rest is hiding in the torque convertor which gets pushed forward in the systen as you do a 5 minute drive using each gear
So the acura easy method for service is a straight drain and refill 1 time 3 qts
Owners like to do it better~
If you have used dex3 in an emergency top off situation- then you have to do the 3x3- which is actually 12 qts not 9,,,to those who read the book~
Now acura made a new way with that tech bulletin- mainly designed for their newest cars with a different trans than we have
It reduces the time a tech spends putting the car up and down and driving- now they simulate the drive on the lift,,
fluid color is only part of the equation- if its not changing colors, its not picking up crud as its designed to.
Smell it to know how its doing!
Many places will look at the mileage and assume it needs certain work done- without the tech even saying it needs a trans service- service writer decides it does,,,
oh- 90k miles?? you must need a flush on all the fluids
Never mind the fact you did it all a month earlier--- they dont even look in their own records to see what they have done!!! let alone look at the car!
I am going to tell you from personal experience that your trans is toast. I was going through the same thing about every 7.5K miles where the fluid was turning dark. Eventually the code for AT internal malfuction was set and I got a new trans.
Great post!
Perhaps, we could create an area on the forums and list any TSB for our cars.
