Help choosing brembo brake pads
I am looking to get new front brake pads for a TL-S. What do you guys think about these 3?
Racingbrake Brake Pads ET500
OEM Acura TL w/ Brembo
Rotora Ceramic Brake Pads
Do the ceramic brake pads provide more stopping power??
AZ Community Team
Received 7,771 Likes
My first pad change on the '07 TL-S, I stayed with OE pads. I did not need new or turned rotors, so I wanted to stick with the same compound.
If/When I do change the rotors, I am leaning strongly toward the Racing Brake ET series pads. I do have the ET500 with RB rotors on my '02 TL-S and like them a lot - Great stopping, no noise, low dust.
ceramics provide less stopping force- and less dust
Wax your rims with synthetic car wax for cleaner wheels!
the ET500s are good pads used by many here, and other cars like corvettes--
get them from MrHeelToe, an acurazine sponsoring vendor, check his signature for secret discount code~
for all hose companies you're gonna need to get the rotors they provide as well if ur gonna use the stock rotors with aftermarket brake pads they wont give u 100% results..... the car had the brakes engineered for it ive tried a brake pads and nothing has worked better than the stock pads...on the stock rotors.
they will work fine on stock rotors-
they work amazing on RBs rotors since they hold up to the extreme material hardness of those rotors
They will last, and stop your car better than stock for sure
I would clean the rotors before install- and flush the brake fluid before you do anything to the brakes
That prevents backwash of any crud- get all new fluid in it and the bad stuff is removed.
I replaced my OEM Brembo pads after 64K miles with the RB ET300s. They are fine with the OEM rotors. I didn't even turn my rotors. Great pads, equal or better than OEM in stopping power, no noise, no dust, and they cost only 2/3 of the OEMs. Be sure you put grease on the back of the pads, on the clips, and on the pins. There are several good DIY threads for replacing your pads.
RPF1+RS3 FTW
I got the Rotex Kevlar gold pads after reading good stuff about them in some other threads on here. You can get them from this site for only $40:
http://www.buybrakes.com/store/DA049D
Enter coupon code FP08010 at checkout.
Just throwin these out there if you don't want to spend $160 for the oem dust machine pads.
Registered Member
Did you get both front sets for this price or is it just for one wheel? Yes, I know it sounds dumb, but that is one heck of a crazy low price! I just went out to my garage to check the part number and it is the same: DA049D. Man, I should just order a set like now to have around when my current set needs replacing.
Registered Member
Oops, just went out and checked my front pads and I still have perhaps a year left on them (if not more). Not a good idea to buy new pads and let them sit in a garage for that long before using them. So I'll just keep the info you have supplied for the time when I need to replace my current Rotex pads. And thanks for the link!!
Registered Member
I might add for the OP's edification that I did several writeups in '06 about these pads and how to properly bed them in when replacing the stock OEM pads with them. This is critical to eliminate squeal and to promote smooth and effective braking. I also did a writeup as I recall, about the performance and visual aspects of the pads. The performance angle addressed normal use and the visual aspect related to dusting. You might want to do a search on all of this, especially the bedding in. And I did these over a few months so don't just read one.
I had to bed them in three times. The first time, I did what the guy at brakewarehouse.com told me to do and it was not right. The next time (and location) was just not conducive to bedding in a set of new pads. The third time was the charm. Basically, you are going to have to do 8 to 10 hard brakings from 60 MPH down to 10 MPH (do NOT stop) 8 to 10 times in a row. You accelerate rather quickly to 60 then hit the brakes pretty hard (this side of ABS) to take the car down to 10 MPH. Then back up to 60 quickly and back down to 10. After the 5th or 6th braking, you should encounter fade. Don't worry, this is a good thing. Do this 8 times on your first bedding in venture. After the 8th time braking down to 10, drive the car normally for 15 to 20 minutes and do not stop. Use the brakes as little as possible during this cool down period. After this, you should be Ok unless you have to repeat the process.
The purpose of this is three fold. (1) Promotes gassing out of the new pads. (2) Forces the new pads to "marry" themselves to the rotor surface groves. (3) Transfers pad material onto the rotors.
What are the differences between the Racing Brakes ET500 and ET300. Is it just the hardness of the material? I do not want to harm my oem brembo rotors.
RPF1+RS3 FTW
Alright, I am going to ask a stupid question here if you don't mind. It's possible you may have read my postings about these pads since I installed them almost three years ago on my '04 manual TL. My question is this.
AZ Community Team
Registered Member
I don't have them yet I should be getting them this week. Once I have these and my SS lines I can go ahead with the conversion. I will definately follow your procedure on the bedding process. Hopefully I can find a nice area where the cops won't harass me lol. Its going to be tough where I live in Los Angeles. Sorry officer I need to hit 60 on this street in order to properly bed my brakes ![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
In LA, you might have to go east for a bit before you can find any sort of highway where you can do this. Good luck.
AZ Community Team
