Help Changing Bulbs on Outside of Car
Old Nov 10, 2010 | 03:35 PM
IDM's Avatar
IDM
Are there directions for changing all of the outside bulbs for the car? I did the inside with LEDs but the outside doesnt seem to have access to the bulbs.
Thank you
Old Nov 10, 2010 | 11:01 PM
NCTL05's Avatar
Middle Finger anyone?
Can you be more specific as to which ones you're trying to change? Your question is vague.
The direct answer to your question is yes. There are directions.
Now we need to know which ones you're trying to change out so we know which directions to give you. k
Old Nov 11, 2010 | 09:01 AM
IDM's Avatar
IDM
Okay I need help changing the rear license lights, and the reverse lights.
I also want to change out the front turn signal bulbs, and both reflector bulbs.
lastly I want to put HIDs on the DRLs.
Thank you
Old Nov 11, 2010 | 09:14 AM
TheChamp531's Avatar
Chapter Leader (San Antonio)
All the DIYs and information can be found in the 3G garage.
Click Here
Old Nov 11, 2010 | 09:17 AM
Also, just take a look at the licence plate.
How do you think you can access it?
remove some of the padding in the trunk. there are plastic clips that hold the trunk liner in place.
Old Nov 12, 2010 | 12:55 AM
NCTL05's Avatar
The front turn signal bulbs are kinda a hassle. But not a big deal. Depending on the side your working on turn your wheels to the inside so you can access the front part of the inner fender splash shield. Undo a couple clips and peel back the liner. You'll be able to see the the plug for the turn signal bulb. Undo that and swap your bulb.
The front reflector is similar. Except you have to peel back the back half of the fender liner. You'll be able to see it. The rear one might be accessible through the trunk. I'm not sure though.
Old Nov 12, 2010 | 07:47 AM
IDM's Avatar
IDM
can anyone give me a link to installing all these bulbs? I would rather not sift through hundreds of pages to find it.
What I really want to swap out right away are the vanity mirror bulbs. and rear license and reverse bulbs
Old Nov 12, 2010 | 07:53 AM
take out the liner on the trunk. its held by plastic clips that you use a flat head screw driver to pop off.
next, reach into the the license plate area from behind. pop out the little plastic covers. you'll expose the bulbs. now disconnect the bulbs. put new LED bulbs in and do the reverse to put back together.
the only way you'll know what i'm talking about is if you go in and explore for yourself. you wont hurt anything in the trunk.
ALSO, IDM.....we have something called the 3G garage. read through some of the threads. I'm sure you can find what you're looking for. STop being lazy and shift through the threads...
I found the DIY. heres a hint. go to The Champs post. he posted a link. click that link. then click on the DIY section...it says CLICK HERE TO OPEN AND SEE LISTINGS OF TOPICS.
then press ctl+f...then type in e-035
Old Nov 12, 2010 | 08:17 AM
IDM's Avatar
IDM
when you get a full time job youll understand
Old Nov 12, 2010 | 08:29 AM
I'm at my full time job, sir.
https://acurazine.com/forums/3g-tl-2004-2008-93/e-035-diy-how-remove-trunk-liner-pics-763693/
i did not check to see if the pictures are still there, or if its the correct info.
Old Nov 13, 2010 | 07:55 AM
NCTL05's Avatar
WTF is that supposed to mean. It's sad that you bite the hand that feeds. I have a full time job as does most everyone else in this forum. If you care about your car at all then you'll take the time to figure stuff out on your own. I try to help the noobs but they don't listen. Noobs need to search.
Old Nov 13, 2010 | 09:40 AM
pwr2panda's Avatar
honestly the best thing to do for threads like this is post up link to The Garage and close the thread...
Old Nov 13, 2010 | 10:16 AM
CLtotheTL32's Avatar
USE THE SEARCH FEATURE. Don't like the one here on Acurazine? Go to Google and type in "Acurazine +" whatever you want to search for.
Jesus. I feel like the main page of the 3G section is full of questions that are answered in the 3G Garage.
Old Nov 13, 2010 | 11:03 AM
SharksBreath's Avatar
BANNED
that's because it is...
everyday there are questions on the main page that have been answered numerous times. it's quite alarming how people cannot do a simple search. google yields everything you would ever want to know. the search feature here on the forum will as well. you just need to take the time to search. i always hesitate to ask a question here bc once i take a few minutes to search, BOOM there it is everytime.
Old Nov 14, 2010 | 04:49 PM
millarduck's Avatar
If you own a 2008, see page 301 of the owner's manual.
I can't speak for other years.
Old Nov 17, 2010 | 08:13 AM
IDM's Avatar
IDM
what about the bulbs for the vanity mirrors how do you pull the lenses off of those?
Old Nov 17, 2010 | 08:18 AM
I havent taken a look at the vanity mirror lights.
when you look at it later today, IDM, see if a butter knife can pull it out.
use a butter knife.
use a cloth draped over the knife. this protects your car.
try prying the light covers off.
Old Nov 17, 2010 | 10:01 AM
IDM's Avatar
IDM
use a butter knife.
Thanks I did pull off the rest of the covers but im really concerned about breaking these. I couldnt get them to come off no matter what I tried.
Old Nov 17, 2010 | 10:03 AM
Search through some of the threads regarding this.
check to see if its even do-able.
Old Nov 17, 2010 | 11:15 AM
BANNED
the vanity mirror lenses are almost like they're "glued on" so to speak. but...they will come off. work all the angles and sides on the lense cover, you will see a clip on the left hand side in the middle. that clip is basically what holds the lense in, minus the glue like material that sticks to your ceiling cloth.
i got mine off fine, it just took a bit longer than i'd liked.
Old Nov 17, 2010 | 12:58 PM
stvtec's Avatar
'06 WDP TL 6MT
Old Nov 18, 2010 | 03:33 PM
Shring's Avatar
actually the search function on just about EVERY vbulletin forum sucks ass...searching rarely pulls up anything relevant to what I search.
Old Nov 18, 2010 | 03:48 PM
IDM's Avatar
IDM
even if the answer is there so what theres not so much activity here where the threads are in the way. Its a chance for members to help each other out if they can. The owner of the forum will appreciate it too more activity is more revenue from the site. Basically if you dont want to answer just move on theres no reason to post rude search search search messages
Old Nov 18, 2010 | 05:36 PM
Dat Boi Ralph's Avatar
2004 SSM FTMFW !!!!
2012wagon
Sep 29, 2015 04:21 PM
jfman55
Sep 5, 2015 02:55 PM
brjones9
Sep 3, 2015 07:30 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
Mcj270
Aug 31, 2015 04:45 PM
