HELP! Aspec front lip bumper
Old 08-24-2015, 02:16 PM
pplcrew's Avatar
Hi all,
I have a noob question to ask regarding diy aspec type s front lip bumper.
Do i have to cut the bumper in half in order to install the aspec bumper or is it simply installing them on top of the original bumper?
I have the pdf file but I still don't quite understand how to diy...
Old 08-24-2015, 02:50 PM
01acls's Avatar
No cutting of bumper. Just drilling holes and adding on top of bumper.
Old 08-24-2015, 09:21 PM
Acura93's Avatar
I believe you don't need to cut any thing to make it fit!
Old 08-24-2015, 09:38 PM
truonghthe's Avatar
Received 1,692 Likes on 1,307 Posts
no cutting, just need to drill holes.
Old 08-24-2015, 10:57 PM
Sǝxy Timǝ in my
smsTL's Avatar
I just installed A-Spec on my Type S TL few days ago. No cutting required. There should be pre-marked circles where you need to drill holes. If you have standard TL yours might be a bit different...I believe it comes with templates tells you where to drill the holes. I find it easier to have the pdf printed out.
Old 08-25-2015, 04:05 AM
pplcrew's Avatar
Thanks guys,
Additionally, why is exactly adhesive Seal A and Seal B required to attached for the fog light grill ?
There is six retaining tabs that are already on the trim or "fog light grill" that fits right into the spot.
Old 08-25-2015, 08:45 AM
Received 16,263 Likes on 11,973 Posts
so, they initially made it without the sticky tape, only to find that it pops out a bit....so the solution honda came up with is sticky tape.
Old 08-25-2015, 06:08 PM
pplcrew's Avatar
Due to all of you guy's help, i was able to install without any troubles !
Thanks !
Old 08-26-2015, 01:33 AM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
congrats man
im just curious, where did you read or get the idea you have to cut the front bumper in half?
or did it just pop up in your head that you needed to cut the bumper in half to install it?
the pdf doesn't mention any cutting
obsessedmotors
09-10-2015 10:49 AM
08 NBP TL
09-08-2015 08:49 PM
leerbgdup
09-06-2015 11:01 PM
Pegon95
08-31-2015 02:18 PM
Quick Reply: HELP! Aspec front lip bumper
