Headlight upgrade help
Have anyone tried or have done the upgrade their light to 6000K or above? In addition, how hard to just get the bulbs out and check the spec?? any info is greatly appreciated it. Thanks.
9.5+10.5 22m=Hella Flush
Originally posted by zima76
WOW.... what a work.....
This means for those people with full body kit (my self included), we need to remove the front air-dam first, then the bumper to change the headlights to some thing that looks cool but will not pass inspection (at least here in NJ). This translates to remove & install before inspection, again after inspection, every 2 years. Wonder if it's worth this much trouble.
getting 6000k bulbs isn't an "upgrade". it's a color change at the cost of reduced lighting. the 6000k bulbs are ~25% dimmer than the stock 4100k bulbs.
when HID first came out, everyone wanted their yellow halogen to look like the "white/blue" 4100k HID's. just about everyone gets suckered into buying blue-tinted halogen bulbs. now that everyone has HID's, people are getting suckered into buying 6000k bulbs, reducing usable light output.
some things never change.
usc is right the light output is less with the 6000K, although the purple hue does look pretty cool you are actually "downgrading" light output. personally i like the purple look but would not want to sacrifice performance. the TL's HID's are pretty damn bright and the color perfect, almost pure white on the road and a little blue/purple tint. doesn't make it look cheap.
You dont have to remove the bumper. If you take a look behind the headlight. Just use a torch screw and take the cover off the HID area and twist the silver (thingy). Then you will see the bulb. The bulb is held down by a metal clip. Push the clips down and out then pull the bulb out. Make sure you pull the bulb out straight because if you break the rod you need a new bulb...
Hey guys I think that if you get the 6000K philips or osram bulbs they r official without any light output loss just because they r basically oem. If anything the osram ones that are D2S for the 04 tl have a lil blue in em, the 6000K osram d2s has a darker blue with a lil purple and the light output stays the same I have spoken to a phillips tech about it because i was concerned with an ML55 bulb replacement I did for my friend. the philips d2s is whiter with a lil blue thrown in and no output loss either they guy said if u get those wack rebased D2S and D2R bulbs ur lookin for output loss because they r not oem replacements.
and if you live in an area when it rains fairly often, you'll definitely notice a decrease in light when driving in the rain at night. the bluer light gets absorbed into the asphalt and you'll hardly see anything other than reflective street signs and road reflectors.
Originally posted by Skeedatl
What's wrong with white light? Are people wanting blue just for the sake of blue?
Registered Member
Originally Posted by usc
no, the light loss is documented from the official specs from Philips. bluer light scatter more easily, hence, would appear just as bright, or slightly brighter (because it's a little more glaring). but there's a ~25% decrease in usable light as compared to the stock 4100k.
The poster should give this some more serious thought before making the switch.
Forced Induction
yea anything over 4100k - 4300k is going to have less output, yes it will be blue but who cares?
its looks blue due to the optics of the lense already, and I am a person who prefers function of looks.
Registered Member
If you really want to increase your usable light to the road surface and surrounding area, replace the fog lamps with Philips Premium lamps. I've done this to several of my cars in the past and it is worth the switch for more light output. I just ordered a set last night for my TL. Where I live, there are a lot of four-legged creatures, some quite large, that you do not want to hit with your car. Virginia is lousy with deer and western Prince William County is no exception.
Forced Induction
Originally Posted by dooky211
IMO, Stock S2000 HID's are the Brightest!!!!
btw..........if you add a few washers in the TL projector shield, it will be a bluer cutoff, but it requires you to take the lenses apart...........which I will not do, because of the leaking, and most modified lenses leak as I have learned from my previous car.
