Headlight modification questions !!
Old Apr 3, 2016 | 09:32 AM
Enrick Gatien's Avatar
Bigboy6029
So I'm finally gonna clear my headlight and put some switchbacks on! The thing is i want to change the daytime running lights too to some less or xenon(well i don't even know!) but white bulbs ! I'd like to change the high beam (OEM xenon) to blue lights ! So what i need to know is what is the bulb model that i need for these and what brand do you recommend !
Plus, It seems like the inside of my headlights are worn a bit, do you have any suggestion of things i could do to get that cleared ? Since i'll have them opened up when i'll clear the turn signals. (Without buying new ones !) Just got them polished(outside) about 2 months ago so i'm sure it is inside!
Spec:
Acura Tl 05
Base AT
P.S. I live in canada! and i speak french if it can help !
Thank you !!
(For the pics, the yellow one is DRL and the white one is the high beam)
Attached Thumbnails Headlight modification questions !!-img_0537.jpg   Headlight modification questions !!-img_0538.jpg
Old Apr 4, 2016 | 09:30 AM
maharajamd's Avatar
Welcome. Try a search next time. Although there may not be a DIY exactly for this there are certainly tons of threads with this information.
The inner section on those lights is technically the 'fog' light. In 07-08s those became DRLs. A lot of 04-06 guys install a module to make that light a DRL or, like myself, hack up the harnesses so that it is independent of the accessory lights.
Some guys install LEDs there simply for the looks. Some guys install HIDs there for the output. The choice is yours.
Fog lights are most useful the lower they are. Also the more yellow the bulb the better (cuts through the weather). So if you intend to install Inspire lower fogs or do an Accord retrofit in the lower grill, my advice would be to find a LED bulb that matches whatever headlight bulb color you choose. And install some 3k HID in the lower fogs. If you don't want to do a lower fog retro then I would do 3K HID in the headlight 'fog'.
As for the main headlight bulb, remember, the higher in kelvins you go the less output you'll receive. My advice would be to go no higher than 6K. Morimoto, CBI, oem are about the only bulbs choices I would choose for those. CBI being the best output, oem good all around, Morimoto being good on color/output/cost.
The perfect setup IMO, CBI for main bulbs, LED matched in the 'fog' area modded independent for manual DRL, accord lower fog retro with 3K HID.
As for polished the inside...just do the same as the outside. Although I will say this, as someone who has opened their lights many times, the less you do/touch/handle/fingerprint/breath/dust/etc on the inside of your lights the better. Like the 'chromed' reflective pieces? Yea..don't touch those. If you do, don't rub your fingerprints off too hard.
Another tip, source some super big ass silica gel desiccants to stuff behind the lights on the inside. Like what comes in shoes, etc. Heck I got mine out of my iMac box. There are some in there stock, but by now, they need replaced and you can fit more in there. The more the better.
Also if you're going in that deep you might as well swap out the lenses and upgrade to ZKWr's.
Old Apr 4, 2016 | 12:01 PM
Oh Sickest TL's Avatar
Jeff
D2S is the HID bulb you need for the high beam . DRL is a 9005 bulb (canada) so get a LED 9005 bulb but you'll need a R3 decoder harness so it'll work
Old Apr 4, 2016 | 02:27 PM
Bigboy6029
Thanks for the reply! I still have questions if you don't mind !
I dont get the difference between DRL and my "fog lights" ?
I wont do the lower grill conversion so should i keep the yellowish light(inner part of the headlight)?
As for the high beam i tought that 8-12000k was blueish and 4-8000k was white am i wrong or i just dont get it ?
What do you mean by making the fog independant accessory ?
For the chrome pieces inside, i was gonna paint it black with some special paint, any toughts ?
Thanks a lot ��
Old Apr 4, 2016 | 02:42 PM
maharajamd's Avatar
DRL run during the day for safety. Fogs are suppose to be used when needed. I'm pretty sure the 07-08s have a sensor and those lights come on automatically when it's dark enough.
I would. But I'm more function than form when it comes to lights.
Stocks are 4300 or 4500 or something like that. 5K is the sweet spot. 6K if you really want that "ice blue" look. But IMO, 5K is what you want. A tad less yellow than stock but still has good output.
To use the inner lights (fogs or what you thought were DRLs), with the stock lever switch by the steering wheel, the accessory lights normally have to be on. You can mod the harnesses so you can use that switch independently.
https://acurazine.com/forums/third-g...switch-772633/
Yep that's what most of use do. Black out the headlights. Tons of threads here about that.
Old Apr 4, 2016 | 09:51 PM
Bigboy6029
Is it that hard to do ? Or just plug decoder to the original wire and put the bulb in ?
Btw does any1 know where to buy the a-spec or type s lips to add on the base tl i cant seem to find it ?
Old Apr 5, 2016 | 12:32 PM
Jeff
no its not hard to do. you can order it on ijdmtoy.com . And your in Canada so you have DRL 9005 bulb
Old Apr 5, 2016 | 02:42 PM
Bigboy6029
Is it these models ? I just dont want to f*ck up and be sure ! :p
HID Conversion Kit Wire | HID Relay Kit | HID 9005 9006 Relay Harness Wiring
H7 H11 9005 9006 5202 P13W LED Daytime Running Light Fog Bulbs
D2S HID Bulbs - D2R HID Bulbs | Xenon HID Headlights | HID Light Bulbs
Thanks !
Old Apr 5, 2016 | 02:47 PM
mazen222's Avatar
They're not easy to find around here... i had to get mine from New York Acura dealer. You might be luckier since you have a 05 (i have the 07 with fog lights)
Good luck
Old Apr 5, 2016 | 07:05 PM
Jeff
Harness
Acura Honda Lexus High Beam LED Daytime Running Lights Decoder Modules
select R3 option
DRL LED Bulbs (9005)
9005 LED Bulb | eBay
Headlight HID Bulbs
https://www.theretrofitsource.com/mo...l#.VwRSNFz4vHg
Old Apr 17, 2016 | 09:29 PM
Bigboy6029
As you guys can see, its cracked from the inside ! So do you guys suggest anything to repair them? Open the light and Put something on it then buff them, i wanna clear them anyway so i will have to open them up anyway! I aint buying new headlight and acura wont sell the plastic only so help plzz i want it to look so good !!
Thx
Old Apr 17, 2016 | 09:53 PM
Jeff
2 options. new headlights. or buy new plastic which is not sold separately so you'd likely have to buy headlights from a junkyard. open those up and take the lens.
You can try opening yours up and sanding then buffing then clear coating the lens but as far as I know you can't buff cracks out
Old Apr 18, 2016 | 08:10 AM
maharajamd's Avatar
Sadly I agree. I'm not sure there is much you can do about that.
If anything contact one of the forum vendors. They may have extra lenses laying around that if they did your lights they could save you from having to replace them entirely...
Old Apr 18, 2016 | 08:13 AM
Bigboy6029
Like AckTL05 ? I really like his work! Does he still work on headlights ? How can i reach him ?
Old Apr 18, 2016 | 08:14 AM
maharajamd's Avatar
Yes like Bruce. There are a couple "mod your light" type guys floating around here.
Or just find a pair of used lights. I think there was some in the BM.
Old Apr 18, 2016 | 04:53 PM
mvp2765's Avatar
Unfortunately those headlights lenses aren't repairable. You can either buy new headlights or find cheap used ones on the BK Market. I had the same thing happen to brand new set of depo headlights that i modified for my Z, and i had to bite the bullet on a second set just for new lenses.
Old Apr 19, 2016 | 01:04 AM
crbnfbr's Avatar
If you don't wan't to use your DRL's as fog lamps it sounds like you'd be better off with a 1000lu 9005 that isn't obnoxious to oncoming traffic, if they make one that is? My personal opinion go with a 65w 9011 bulb, even with the lower voltage they'd be great
A link from a different post I made in another thread I made about my 9012 fog lamps.
https://acurazine.com/forums/third-g.../#post15730073
Old Apr 19, 2016 | 07:04 PM
Boosejars's Avatar
I have the stock D2S lenses if you want, I modded my headlights and replaced them with the Zkw-r lenses...so if you want to do that, send me a PM and we can discuss.
Old Apr 20, 2016 | 07:44 AM
maharajamd's Avatar
I think his projector lenses are fine. His headlight lenses not so much.
Old Apr 20, 2016 | 07:48 AM
Bigboy6029
Well all the lights and light bulbs are good, itnis only the headlight cover, the top plastic part that is spider cracked so thats the thing i need to change im guessing
JJones91
Oct 17, 2016 06:52 PM
bentleyvtech
Mar 20, 2016 08:23 AM
Mr. Showtime
Mar 18, 2016 10:36 PM
