Are the headlight lenses on the 3G removable?
Old Jun 22, 2016 | 03:53 PM
TheyGotMawty's Avatar
The inside of my headlight lenses are oxidized and makes for very dim headlights. I was wondering if I could remove the lens in order to clean them. I can't find lenses for sale online, so I'm not sure if they're removable.
Old Jun 22, 2016 | 03:57 PM
EvilVirus's Avatar
Are you sure its the inside? Take pictures and post them here.
Old Jun 22, 2016 | 04:12 PM
GOOSEej's Avatar
Lenses do come off put you have to heat them up via oven or heat gun... Its takes time once off you can clean the inside of the lense.
I have the problem where the outside of the lense is nice clear and clean but the inside needs to be wiped down also
Old Jun 23, 2016 | 07:04 AM
imakeholesinu's Avatar
Good luck getting the assemblies out, you'll have to remove the the bumper, Windshield wiper bladder and pump assembly on the passenger side and the cold air return assembly on the drivers side to get to the last two bolts that hold the HID assembly to the headlight (two bolts).
Old Jun 23, 2016 | 09:00 AM
yeah.. are you sure it's the inside
just get new headlights, it'd be much easier.
There's one here:https://acurazine.com/forums/car-par...4-06-a-944954/
Old Jun 24, 2016 | 08:06 PM
BoneStock04TL's Avatar
I've removed my headlight assemblies about 8 times now and never ran into that much trouble. The first time is a pain figuring out where all the bolts are to remove the bumper and the assemblies themselves.
But I'm not sure I would open them up myself, if you are set on fixing your current headlights have someone experienced do it.
Old Jun 30, 2016 | 11:02 AM
Boosejars's Avatar
So - the headlights do come apart. However, none of the components are sold separately, with the exception of the turn signal diffuser, other than that you have to buy the headlights as a whole unit, unless you know someone who has back up supplies as a headlight modding guru. It is not impossible to do the diy, however, if you not confident in mechanical abilites, and patient with small pieces - then reaching out to those who are more experienced will help you out a great deal. Bruce O'shack (endlessrpm) and Ross Beckner (aroracustoms) are the only guys I would trust my headlight too. I did mine on my own here are some shots just to show you how many pieces there are -
-After baking - the two halves separated
20150529_205438 by Matt Werson, on Flickr
-all components taken apart - only thing not pictured are the turn signal diffusers
20150530_073442 by Matt Werson, on Flickr
-this is after i painted all the parts - i blacked my housing out, and painted the drl/d2s bezel and the chrome turn signal strip purple, and have smoked turn signal diffusers...
20150601_105950 by Matt Werson, on Flickr
-smoked diffusers with CF wrap on ends installed back into the shrouds
20150601_122245 by Matt Werson, on Flickr
-everything back together baking to reseal
20150601_135925 by Matt Werson, on Flickr
-finished product - i also took the time to upgrade the d2s lens from the stock fresnel lens to a clear ZKW-r lens - much better light distribution and better light cut off..
20150601_171125 by Matt Werson, on Flickr
Sorry, that may have above and beyond your initial question lol - just trying to do some elaboration - but if you're not looking to get the lights modded I would just get a replacement set, easy enough from part outs and ebay etc...however Bruce and Ross can mod you existing lights, clear up and seal the lenses and you're all set....just depends on the route you want to take and how much time you're looking for a turn around...
JJones91
Oct 17, 2016 06:52 PM
nfnsquared
Jun 1, 2016 07:13 PM
MasterDavid
California
May 28, 2016 02:46 AM
bentleyvtech
Mar 20, 2016 08:23 AM
Mr. Showtime
Mar 18, 2016 10:36 PM
