headlight, drl, fog lights are aimed off after install....
Just installed cleared headlights on 07 model TL and I guess I did not put the headlights as EXACT as it was before so my lights are not adjusted correctly.
I know I can adjust the headlights but how do I go about adjusting the DRL beams and the foglights? The foglight and drl on the left side of car are aimed lower than usual and the right drl and foglight are aimed higher than usual and you can see it on a white wall.
Does this mean I have to realign the bumper and the headlight? I really do not want to remove the bumper again....
DRL bit is connected to the low beam projector so once you adjust your low beam it will automatically adjust the DRL.
As far as adjusting the fogs, you should be able to do it through a hole towards the underside of the fogs/bumper, you would need a phillips head screwdriver for both headlights and fogs.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
