Headlight Chime Buzzer Delete
Old Apr 14, 2018 | 12:44 PM
Levon05TL's Avatar
Morning! I have searched above & beyond for an answer and I can only get info on exact location of Buzzer on 2G TLs. Anyone knows where the buzzer is exactly located? I know it’s left side driver but I need more specifics please. The headlight on chime annoys the shit outta me! Thanks for any info.
Old Apr 15, 2018 | 02:36 PM
Turn the headlights to off
Old Apr 15, 2018 | 03:55 PM
Pair of TLs's Avatar
Trace it down while it's chiming, and stuff a towel around it--you'll feel so victorious every time you hear that muffled sound!
Old Apr 15, 2018 | 04:00 PM
Levon05TL's Avatar
😂 simplest fix I ever read. Kudos. I like how it greets me with its headlights as I unlock it at night.
Old Apr 15, 2018 | 08:03 PM
guitarplayer16's Avatar
That makes sense, I could see it being nice.
I personally don't do it just because I get paranoid about shortening the ballast or bulb life when I crank the car with the headlights on.
Maybe I'm TOO paranoid, because when I think of it, all these modern cars have auto-on headlights and most people leave it in auto mode, which means the headlights are on at night when they start it up. They don't don't seem to be experiencing any problems I suppose.
Old Apr 15, 2018 | 09:36 PM
Levon05TL's Avatar
ofcourse as with everything the more the lights run the shorter the life of the bulb and ballast. Who’s counting? Ballasts readily available at junkyards for $15 each.
Old Apr 15, 2018 | 11:07 PM
It's not so much the fact that the headlights are running longer, it's the fact that voltage fluctuates when cranking the car.
You've obviously never seen the prices parts go for in Canada.
$15 each, AND readily available? Please, send me some
Old Apr 16, 2018 | 01:29 AM
Levon05TL's Avatar
smart! Tomorrow’s project!
Old Apr 16, 2018 | 09:39 AM
KISS: Keep it simple stupid.
Old Apr 16, 2018 | 09:40 AM
I agree
auto headlights are 'great' for safety, but wreak havoc on the life span of ballasts.
Old Apr 16, 2018 | 01:03 PM
Cool
Use a small microfiber towel--color matched, of course!
Auto is fine, and it's actually good to run low power through the wiring to "warm it up" for the big voltage to kick in the starter motor. You should turn off the radio, heater and auto headlights if you want to get the most cranking juice for starting. Then flick the H/L back to auto...
Old Apr 16, 2018 | 05:53 PM
WDPanda's Avatar
And it's not just a 'simple ballast' in these cars. You'll have to remove the whole front bumper and lights and trouble shoot the ballast/ignitor/bulb/fuse. Not fun.
Old Apr 28, 2018 | 10:10 AM
Levon05TL's Avatar
Morning fellas. Update!!! Buzzer is part of the gauge cluster. Now I’d rather cut the wire which gives signal to the buzzer rather than disassemble the whole gauge cluster and destroy the little speaker. I know exactly which connector but don’t know which wire . Anyone can provide wiring diagram for that area? Much appreciated.
Old Apr 28, 2018 | 08:23 PM
Like I told the guys in 2G--stuff a folded up micro-fiber towel up there to muffle it, and feel victorious every time you hear that muffled chime. Plus, you don't damage it for the next owner.
Old Apr 29, 2018 | 10:00 AM
Levon05TL's Avatar
i taped every single hole on the back of the cluster and put dynamat material behind and on top. Sound a liiiiittle bit lower. However, it still travels through the front so that’s not a solution. I’m thinking of installing an on/off switch and hiding it under once I figure out the wiring.
Old Apr 29, 2018 | 03:02 PM
Small victory?? Switch sounds like a good trick. When you figure it out, post for everybody. Good luck!
Old Apr 29, 2018 | 03:11 PM
Levon05TL's Avatar
i guess we can call it that! All i need is a wiring diagram and I’m done. Will def post a tutorial.
PhillipMG
Sports Talk & Fantasy Leagues
Feb 25, 2009 07:13 PM
jcondon
May 1, 2008 08:31 PM
voltech
Feb 22, 2005 02:30 PM
SilverSeriph
Jul 30, 2002 03:22 PM
