Headlight
Old Mar 15, 2013 | 08:19 AM
  #41
Nick216's Avatar
The Boss
^^ my tracker says monday too but there alredy in NY, and its been 2 days 0.0... ill post pics aswell i guess
Old Mar 15, 2013 | 11:52 AM
  #42
Nick216's Avatar
The Boss
got my bulbs and i got my oem ones out i just cant get the dam things in. wen ure putting the connector back on, do the tensioners go on first. and wen u put the connector in does it go in sideways then turned straight?
Old Mar 15, 2013 | 12:00 PM
  #43
nate_0022's Avatar
Land of 10,000 lakes
Bulb goes in first. You have to definitely make sure the marking line up with the bulb holders otherwise your output is going to look like crap. On top of the base of the bulb, you will notices one rectangular notch and one half moon notch. The rectangular notch goes at 12 O'clock, and the half moon notch goes at about 1 O'clock. Once the bulb is in seated correctly then you close the bulb holder prongs. Next you will see a ground wire coming off the bulb ignitor, that gets plugged in on top of the bulb entry, you will see a little prong it slips onto. Finally you are going to put the igniter on the base of the bulb, the top of the ignitor will slip on at about 10 or 11 O'clock, you will feel it seat onto the bulb and twist it clockwise and it should sit at 12 O'clock.
Old Mar 15, 2013 | 12:40 PM
  #44
Nick216's Avatar
The Boss
^^ i had a retard moment i was putting th bulb in the connector first and the tensioners were geting in my way. i got my passenger side in, tn ima see if they look good then ill continue wit the drivers.the drivers side is way tight for the torx screw and im geting angry lol.
Old Mar 20, 2013 | 08:29 PM
  #45
KL 2's Avatar
CBI Osram HID looked like I have to work on swapping Stock lens to ZKW as well....so I just ordered one pair.
And I planning to take off the front bumper to out ZKW in and I think I would want to black out the headlight as well. HOWEVER, one thing came up in my mind, if i painted inside of headlight black just like other guys do, my headlight will be darker??
headlights use reflection to shine light, right??
Old Mar 21, 2013 | 09:08 AM
  #46
Nick216's Avatar
The Boss
A Quick pic of my CBI's, with only like 15 mins on them. ^^ and no our lights dont use reflectors, they are projectors. so blacking out is fine. only the crappy halogen headlights use reflection.
Old Mar 21, 2013 | 09:29 AM
  #47
Undying Dreams's Avatar
Our headlights DO not use reflections to shine the light forward, that's why we have a projector, the glass focuses the light.
To do the ZKW-R swap, you're going to have to take the headlights off the car and bake them to pull them apart, there is no other way of swapping the lens out.
Old Mar 21, 2013 | 09:38 AM
  #48
Sick TLS's Avatar
**The Catfish**
If you paint the whole housing black on the car, not sure about 06 but you cannot paint the reflector for the fog light black, your fog light output will be diminished. Same thing goes for the turn signal reflector. The headlight will NOT suffer tho.
Old Mar 21, 2013 | 09:44 AM
  #49
KL 2's Avatar
I thought the word"swapping" means "exchange"....sorry.
I know the main headlight does not use reflection but how about fog light next to headlight?
Old Mar 21, 2013 | 09:45 AM
  #50
Sick TLS's Avatar
**The Catfish**
I just told you.......
Old Mar 21, 2013 | 09:46 AM
  #51
CLtotheTL32's Avatar
Can you not see the chrome housing around where the fog bulb is located?
Old Mar 21, 2013 | 09:58 AM
  #52
KL 2's Avatar
Ok, so blacking out without blacking out chrome housing around fog light. I understand sir.
Old Mar 21, 2013 | 09:59 AM
  #53
Nick216's Avatar
The Boss
meh headlight foglights suck anyway, aint nobody go time fo dat
  #54
SharksBreath's Avatar
BANNED
i still dont' get it.
  #55
Sick TLS's Avatar
**The Catfish**
nothing like dat free advice doe!
Old Mar 21, 2013 | 10:02 AM
  #56
Nick216's Avatar
The Boss
well since weve got people here, how r my CBI's looking? straight out the box, i need opinions. srry for hijacking
post 46 ^
Old Mar 21, 2013 | 10:04 AM
  #57
Sick TLS's Avatar
**The Catfish**
post 46 ^
cant really tell. should have taken a pic with the fogs off so we could tell better
Old Mar 21, 2013 | 10:05 AM
  #58
nate_0022's Avatar
post 46 ^
We need better quality pics. Shine them on a wall from 25 feet +. Almost seems like they aren't sitting right, your foreground limiter looks a little to distorted.
Old Mar 21, 2013 | 10:08 AM
  #59
Nick216's Avatar
The Boss
ill get pics up tonite, they do have a nice cuttoff, all aligned. ^ maybe cus my driveways on a hill? the fogs do get in the way tho
And OP u said u got CBI's lets see dem pics wth !
Old Mar 23, 2013 | 03:46 AM
  #60
KL 2's Avatar
Can anyone tell me how to make my HID more cut off and more color ?
Old Mar 23, 2013 | 08:24 AM
  #61
Nick216's Avatar
The Boss
zkw lenses
Old Mar 23, 2013 | 08:52 AM
  #62
Sick TLS's Avatar
**The Catfish**
im not sure how many times you need to be handed the same answers and not get it...
Old Mar 23, 2013 | 09:29 AM
  #63
Old Mar 23, 2013 | 02:04 PM
  #64
KL 2's Avatar
I'm kind of slow leaner.
I replaced Osram CBI bulb couple of days a go and I realized that It did not change much of an brightness comparing to my old bulb.
I guess my ballast is dying, cua its been used 7 years...
So ballast used for 7 years, do you think should i replace ballast as well??
Old Mar 23, 2013 | 02:21 PM
  #65
You're not going to notice a difference in brightness. They're like 200 lumens brighter hardly even noticeable.
I recommend you get in contact with our Vendor JnC.
He is our resident headlight modder. For a fee, he will take your headlights and modify them to you liking, including swapping then lens to the ZKW-R. The lens swap will make the most difference in your lights, the "cutoff" is very sharp, unlike the stock lens, which is blurry. The "cutoff" you seem to be lost on, is how the light shines onto the road. It is most noticeable up against a wall where you can see the light stopping at a very fine point, the light is less scattered.
Again, I HIGHLY recommend you let him mess with your lights. It's quite apparent you're lost, sorry to say, but JnC will take great care out you.
Here is his profile: https://acurazine.com/forums/members/jnc-26894/
You can send him a Private Message (also known as a "PM") and discuss what you'd like done.
And here: https://acurazine.com/forums/3g-tl-2004-2008-93/custom-headlights-jnc-part-iii-796033/
is a thread of members' headlights he's worked on.
He does excellent work as you can tell and can modify them to almost anything you want.
Old Mar 23, 2013 | 02:30 PM
  #66
Here is an excellent example of sharp cutoff given by the ZKW-R swap.
And here is an example of the cutoff your stock projector gives off, looks like crap.
Here is a close-up of the ZDW-R lens...
Recap:
Picture 1: ZKW-R
Picture 2: OEM lens
Picture 3: ZKW-R
Old Mar 24, 2013 | 02:15 AM
  #67
dontTL'em'nothing's Avatar
riding low and steady
Theres nothing wrong with your new CBI's. It will take a few months for them to color shift. For your better understanding we will simply refer "color shifting" to "break in period". Pretty much the more you have your headlights on the quicker the "break in period" will be complete, by the way there really isnt a set amount of time as its not all the same for every bulb. Theres no need to replace your ballast if it isnt broken. If you really think your ballast is bad see if someone you know has an extra to try before you buy a new one.
It seems like you are really doing your research but just not able to completely understand it. If your now looking to get a sharper cutoff id suggest you have one of our venders do the work for you. (JnC or AcktL05) I mean if you can spend $185 on bulbs, you can spend the money to have it done from those two vendors who do it routinely. Just saying would make things a lot easier on you. Good luck with which ever route you go.
Old Mar 24, 2013 | 11:10 AM
  #68
Nick216's Avatar
The Boss
ive had my cbis in for the same ammount of time as op, and can say they are getting whiter and whiter each day
also, that pic that shows the stock cutoff, my headlights rely do look like crap. all mis aimed and shit lmao
Old Mar 28, 2013 | 10:47 PM
  #69
KL 2's Avatar
Morimoto 35W ballast would fit with TL 06 without making any holes???
Old Mar 28, 2013 | 10:57 PM
  #70
Why do you want to switch ballasts? Just get new bulbs. You're making this way harder than it is.
Old Mar 29, 2013 | 09:06 AM
  #71
KL...seriously...just stop.
PM JnC and tell him what you want done, and then send him your entire headlight.
Old Mar 29, 2013 | 10:40 AM
  #72
Nick216's Avatar
The Boss
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
