head lights
Old Oct 5, 2010 | 10:43 PM
24no7's Avatar
UA6 SSM TL
head lights
Guys i got my 07 type s head lights so i wonder how hard is the installation?? i will be doing this tomorrow... i was looking for a diy but didn't find anything...
Old Oct 5, 2010 | 10:55 PM
TheChamp531's Avatar
Chapter Leader (San Antonio)
DIYs belongs to the 3G Garage.
Though you didn't search hard enough.
And this is thread: click here
It is fairly easy, you have to take off the front bumper first than everything else is self-explanatory.
Old Oct 5, 2010 | 11:07 PM
NHfastandfree's Avatar
DGP
really easy job!
Old Oct 5, 2010 | 11:11 PM
24no7's Avatar
UA6 SSM TL
i found that, but i don't know if the connectors are the same for the 07 tl type s head lights, tho i know the ballast are different.. is it just plug and play??
ps. i got everything (head lighs, ballast, etc?
Old Oct 6, 2010 | 02:06 AM
It's basically plug and play. All connectors are the same. Just like you said the only thing different that needs to be changed is the ballast.
Old Oct 6, 2010 | 02:39 PM
24no7's Avatar
UA6 SSM TL
the connectors are not the same like you said before. the day time bulbs are different than the ones for the 04 tl. Also, the ballast's plug of the right head light is a little bit different...
Old Oct 6, 2010 | 02:46 PM
AMUA6's Avatar
ScoobyZINE
The Type S headlights take the 9005 bulb for the foglight IIRC. I don't see how the ballast plugs could be different though
Old Oct 6, 2010 | 02:50 PM
LTxArucAx60's Avatar
F-SPORT
07 type S lights uses drl (daytime running lights) where 04-06 use as fog lights so different connectors there. Then the turn signals are different, 07-08 uses round connectors 1157 bulbs and 04-06 uses 7443 bulbs and they are flat connectors.
The housing will be a direct fit but the signals you will have to mod a little to make it fit otherwise a slight bump can knock the signal bulbs out of place and you would have to take out the bumper again. Then try not to use the fogs if you are going to install type S lights, because fogs use a higher temp bulbs and WILL warp and melt your bezels.
As mentioned above post 04-05 ballast are bigger sized ballast compare to 06-08 where they use smaller ballast!
Old Oct 7, 2010 | 10:50 AM
24no7's Avatar
UA6 SSM TL
do u know how to make the running lights work??
Old Oct 7, 2010 | 06:26 PM
Schulminator's Avatar
it's 4:20
I just used LEDs in where the fogs are, no heat so it doesn't warp the lens. I also modded the factory 04 turn signal lamp and socket to fit into the 07 headlight and a little hot glue to hold in place. They have been in for over a year w/o any issues.
Good luck on the install, it's pretty straight forward.
Old Oct 7, 2010 | 06:49 PM
24no7's Avatar
UA6 SSM TL
what kinda glue did u get and where?? what kind of leds??
i had to use one of my 04 ballast since i couldn't connect one of 07 ballast, i hope it won't move but im still worried
Old Oct 7, 2010 | 10:34 PM
24no7's Avatar
UA6 SSM TL
can i somehow make the running lights work??
Old Oct 8, 2010 | 08:56 AM
it's 4:20
^^ use a 9005 LED lamp and switch it with your factory fog switch...
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
PortlandRL
Sep 14, 2015 12:01 PM
Ny1718
Sep 11, 2015 09:21 AM
