HCV or thermostat?
HCV or thermostat?
Ok so, i have a 98 acura el. My temp was up, car was smoking. -Was not over heating. I ha a leak in my hose that controlled heat. K so easy fix.. now my temp is still up and I have no heat in my car... bad thermostat? or heater control valve?
Thermostat was replaced about a month ago! HELP PLEASE
Smoke from where... engine, tail pipe, or kitchen?
You probably didn't purge all the air from the cooling system and/or didn't open the heater valve while purging. Also if the thermostat was installed incorrectly then the thermostat may not open in a timely manner or not at all. Did you do these things correctly?
07TLGUY
Nov 29, 2012 09:12 AM
