Has anyone else noticed this???
Old Oct 1, 2007 | 04:49 PM
HQTL6SPD's Avatar
So i was detailing my car yesterday, this being like the 3rd time in 2 weeks due to unexpected rain ... and I was trying to figure out what causes resistance (sometimes a rubbing sound) when open/closing the doors. This first struck me when I noticed some of my female -umm.. 'friends' struggle a little to open and close the door (especially the rears). So I finally decided to look into it, I looked around and realized that it was this part (ref #1). Do any of you know what kind of paste/lubricant is meant for this part of the door? Is it safe to grind that part down a little (ref #2)? It seems kinda of dry to me, it needs some lube --and nobody say KY-Jelly lol
Here's what i'm talking about:
Zoomed In:
Clayed, washed, and waxed :
Old Oct 1, 2007 | 04:54 PM
AZN.M3NACE's Avatar
USDM -> JDM
WD-40 will do the trick =) i had to use it on my TL because it made an annoying sound sometimes and that was the problem...
Old Oct 1, 2007 | 04:58 PM
Xx06SickspdTlxX's Avatar
06 TL 6spd. Navi/A-spec
That would be the check strap, i wouldnt grind anything down, just lube it up with some grease. White lithium grease will work, i put this on mine and the noise went away!
Old Oct 1, 2007 | 05:03 PM
HQTL6SPD's Avatar
^Forgot to mention that I tried WD40, but that part (ref#2) just wipes it off after a few open and closes. I also wanna know if it's ok to grind that down a little; because this is what causes the door to give that jerking back or forth feel (which feels kinda unsafe in tight situations). It no longer makes any noises, but the resistance is still there. I used to work at Mercedez dealer, and some of their doors are much heavier and open/close smoother...
Old Oct 1, 2007 | 05:31 PM
Wd40 is pretty thin, try using more of a gel type lubricant!
Old Oct 1, 2007 | 05:43 PM
HQTL6SPD's Avatar
^Yea i'll try that lithium stuff and see what happens... but do they come clear or black? Having white greasy streaks in such a visible spot will look like ass ...
Old Oct 1, 2007 | 05:51 PM
I use Honda stuff called UREA GREASE which is a dark green color!
Old Oct 1, 2007 | 06:13 PM
bhelsdon's Avatar
Definitly don't grind it down, the whole point of that piece is to hold the door open for you. I have the opposite problem on mine. Mine doesn't hold good enough, thus resulting in a smashed leg if I am not paying attention.
By the way the detail job looks great.
Old Oct 1, 2007 | 06:34 PM
HQTL6SPD's Avatar
ouch, that sucks...
and thanks!!
Old Oct 1, 2007 | 07:29 PM
Tripnbeats's Avatar
dude dont use wd 40 its a degreaser use white lithium grease...a lil bit all over every hinge n joint u should b ok..... i had a pop noise when it was loose i tightened it n it was gone
Old Oct 1, 2007 | 07:34 PM
darksom1's Avatar
~Da Nocturnal Cheetah~
So what's better? The white lithium or the Honda "Urea"? Jury still out?
Yo HQ...looking real nice there!
Old Oct 1, 2007 | 08:53 PM
HQTL6SPD's Avatar
^hehe thanks! I think i'll try the urea stuff since its made by Honda and hopefully doesn't stand out as much VS the white lithium.... do you grease all over, or just top and bottom?
Old Oct 1, 2007 | 09:03 PM
I usually grease the bottom and top of the check strap, once you open and close the door a few times it will take in the grease.
Old Oct 1, 2007 | 09:16 PM
Here is some info on the super hi temp urea grease the Part Number is 08798-9002 if you are planning on using it!
Old Oct 15, 2007 | 11:56 AM
HQTL6SPD's Avatar
So i ended up buying the white lithium, i'll try it out later...
Old Oct 15, 2007 | 04:43 PM
HQTL6SPD's Avatar
Lithium made a very noticeable difference, but my driver side rear door keeps wiping grease smoothe off, I might consider grinding a little on that one. My pass. rear door opens waaaay smother than before!!!
Old Oct 16, 2007 | 01:40 AM
jchcmax's Avatar
Registered VTEC junkie
Thumbs up
Hey, Kudos on the clay work! SO many people neglect that!
Old Oct 16, 2007 | 04:14 AM
CL Platano's Avatar
Tristate ViP Crew
nice and shiny
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
jpadilla
3G RLX (2013+)
Sep 27, 2015 07:53 PM
urbtsx
Sep 27, 2015 09:40 AM
Brandle34
Sep 23, 2015 07:20 PM
