Harsh Downshift From 3RD Gear to 2ND Only
Hi guys do you any of you have any experience with an 05 TL down shifting harshly from 3rd to 2nd?
It does it when your cruising to a stop slowly. It feels like as if you're puttinf more pressure on the brake pedal.
It only does it from 3rd to 2nd.
I haven't changed the switches yet I am pretty sure that's what it's causing it but wanted to see if anyone had the same experience. Oh also I'm thinking it's the switches because switching to 3rd gear takes longer than others.
My moms 2006 odyssey does the same harsh downshift when slowly coming to a stop.
The car intentionally downshifts to a lower gear while coasting to a stop sign or stop light around 25 mph. When it does this, it feels like a harsh jerk if your not used to it making you think it's transmission problems.
It's called engine braking.
There are times where I am coasting to a stop light at 25 mph and the car decides to downshift and I just so happen to give it gas the same time. Talk about a surprise! The car jerks super hard because of 1. the downshift 2. I gave it throttle in 2nd gear so it will kinda pull you back into the seat.
Yes original. Fluid is dark but it recently had flush done maybe 10k ago. What fluid should I use?
maybe add some more friction modifiers to help out the shudder
I spoke to a mechanic about the shudder and other issues; He brought up the solenoid being one of the major factors. I'm about to go through the painful process of getting my warrantied rebulit tranny fixed this week due to the shudder and harsh shifts. If anything comes up I'll post it here for additional info.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
