Got a Question
Old Aug 13, 2010 | 08:20 PM
rossv1's Avatar
Got a Question
I bought a can of Night Shades tint for my sidemarkers and was just wondering if I could get away with just taping around them or if I need to actually remove them. I searched but couldn't find the answer. Hopefully one of yall can help.
Old Aug 13, 2010 | 08:23 PM
odehboy's Avatar
B A N N E D
I had a bodyshop paint mine for 40 bucks, roughly an hour of labor, consider that?
Old Aug 13, 2010 | 08:25 PM
A SiQ TL's Avatar
Personally, I would remove them. You don't want the spray getting everywhere, or running because you are using it on a vertical surface. The job will look much better if you spray them away from the car.
Old Aug 13, 2010 | 08:26 PM
odehboy's Avatar
B A N N E D
If your going to attempt to paint them I'd definetly removed them...
Old Aug 13, 2010 | 08:28 PM
AckTL05's Avatar
Former Sponsor
They pop right out. I do them for $35 can included.
Old Aug 13, 2010 | 08:30 PM
odehboy's Avatar
B A N N E D
ross what color is your car?
Old Aug 13, 2010 | 10:58 PM
rossv1's Avatar
It's SSM. I know the rear sidemarkers aren't to difficult to remove but what about the fronts?
And Ack, I would but I'm trying to save up for a set of your tails.
And a forgot to ask, what do y'all think about spraying the rear emblems? I thinking about trying to get them to look like black chrome.
Old Aug 13, 2010 | 11:01 PM
odehboy's Avatar
B A N N E D
Find a body shop to paint them SSM, It looks much cleaner than black IMO.. its only 40 bucks and chances are a bodyshop isnt going to fuck up on them...
Old Aug 14, 2010 | 12:01 AM
AMUA6's Avatar
ScoobyZINE
Good luck getting the nightshadez to stick to the emblems.. Unless you do it SUPER LIGHT coats, like barely misting it on. Most people don't do the fronts.. BUT, they pop out just like the back. Loosen the fender liner in the front and reach!
Old Aug 14, 2010 | 01:26 AM
Chad05TL's Avatar
if you gotta ask for somethign this easy, then you better let someone else paint it.
Old Aug 14, 2010 | 01:36 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
If you are skilled/careful, you can get away with taping it off...using a LOT of tape.
Old Aug 14, 2010 | 02:12 AM
AckTL05's Avatar
Former Sponsor
If you paint the emblems they become a black chrome but make sure the bottle is shaken up very well. Also the fronts are a huge pain because unless you have tiny fingers things many break so be careful. They come out the same way but the fender pad is in the way of the door side clip.
Old Aug 14, 2010 | 07:43 AM
VQPower37's Avatar
if your doing any kind of painting work, its best to remove the part from the car, IMO that is how you can get the best job and avoid any risk of getting overspray on parts of the car that you dont want to
Old Aug 14, 2010 | 09:39 AM
images's Avatar
05 NBP
are you the kind of guy that paints around pictures and shelves when you paint a wall in your house?
same thing
Old Aug 14, 2010 | 08:52 PM
rossv1's Avatar
When I put the emblems back on, what do y'all suggest I put them on with?
Old Aug 14, 2010 | 10:18 PM
AckTL05's Avatar
Former Sponsor
Re-tape the sides and they have two plastic nipples that should "hold" it to the car but from the inside I would just throw a tiny bit of sealant or epoxy on it.
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
