Got my ass handed to me by a Galant
B A N N E D
1 Post
Well I jus got out of work after a 11 hr shift. I was all excited ready to go out and party tonite. had the music blastin, no care in the world. I was on the hwy around 85mph when i ended up behind an early to mid 90s galant with a fart can exhaust. I was thinkin to myself that this clown needs to get out of my way so i can make it home. As soon as the guy in front of him moved into the right lane he floored it. I kinda had a feeling he was gonna do that so i was ready for him in 3rd gear at 80mph. as soon as i saw the cloud of smoke and reacted he was already 2 cars ahead. I was like wtf Galants cant do that. So i pulled up to him and paced him at 80 again in 3rd, I floored it first and then he did. We were neck and neck till 6500 RPM and then he started pullin once i shifted into 4th at 7000rpm he was half a car ahead and pulling hard. by 120 he was a good 2 cars ahead. I pulled up to him and gave him the and he did the same. Then we proceed to go into a tunnel and he floored it, all i heard was his exhaust followed by a loud blow off.
I wonder if it was a Galant VR4
Well its time to go party.....be safe guys
On a side note I think i saw the member 01clstock (not sure if i spelt it right) on Highland Ave. I gave you a wave dont know if you saw me.
now with four rings
damn...tough loss...and i was just behind a galant (base model...probably a '94 or '95) the other day thinking how i always wanted a vr-4 back in the day...
in case you're interested...this is a portion taken from the '92 galant press release...
The Galant VR-4 represents a successful blend of the finest attributes of a four-door sport sedan along with Mitsubishi's advanced high-performance engineering technology. Mitsubishi designed the Galant VR-4 system with integrated all-wheel-drive, four-wheel steering, four wheel independent suspension and anti-lock braking (ABS) to deliver exceptional road-holding and handling characteristics.
The Galant VR-4 is equipped with the same high-performance powerplant found in Eclipse GSX: a 16-valve, double overhead-cam 2.0-liter four-cylinder engine that features turbocharged and intercooled induction, electronic multipoint fuel injection, distributorless ignition, roller cam followers, hydraulic valve lash adjusters and Mitsubishi's patented Dual Engine Stabilizers™.
While the turbocharger and intercooler provide a pressurized and cooled air/fuel mixture, the four valves per cylinder combustion chamber design allows increased flow of engine gasses, resulting in a potent 195 hp at 6,000 rpm and 203 ft. lbs. of torque at 3,000 rpm. The Dual Engine Stabilizers™ spin parallel to the crankshaft and utilize counterweights to help offset vibrations commonly found in large displacement four-cylinder engines.
Stock vs stock, a TL-S should have few problems against the VR4. However, modded VR4s are as quick/fast as modded GSTs and TSIs....which means MAD FAST!!!
It is too bad later generation VR4s never made it stateside.
The Boss
You can mod any car and put a turbo in it. Once a car is boosted with a nice turbo, it's no longer the same car. A Galant was a Galant until boosted........... hence you lost.
Pleasure Unit
Originally Posted by denverdandb
the galant vr-4? It's a lancer evo III dude, it comes with the same 16g turbo thats on the newer evo's, same motor even. and all wheel steering, ive had a few, they're pretty cool if you can find one.
Makes the EVO guys look dumb because their car was available in 1990 (in a lower factory HP rating) in a smaller, more aerodynamic package - the Diamond Star turbos......
B A N N E D
1 Post
Originally Posted by berite100
just waiting for someone to come on this site and cry about losing to a minivan soon.... not thats the ultimate sleeper.
He was blown
Originally Posted by ryebreadisme
Pretty hard to find. And being over a decade old, pretty stylish for back in the day...
If I recall Car and Driver's review of the VR4, their comment on the 'Lows' was that it had 'styling by Frigidaire' .
True, but nothing beats that little stamped metal badge on the dash that says "your car is #xxxx / 2500, or the easy possiblity of having over 500hp from such a small car. I think they only had around 3500 or 4000 in the states. You can still find them, theres a black one, 1991 for sale here, has 77,000 miles on it, perfect condition, theyre asking like 3,000 for it i think, has a bunch of factory goodies from rallyart on it too...
It is rare car indeed. However, I would not exactly place its rarity in the same vein as say a 1989 Pontiac Turbo Trans Am (of which ~1,500 were produced and typically sells for no less than $15k nowadays).
I need 2 more gears
the VR-4's were rated at I believe 280hp and 271/tq stock and weighed about 3350lbs. Ran 0-60 in about 6 flat and 1/4 in 14 flat. very powerful still and with mods are monsters. I've never seen one in person, but I'd love to run with one just to see how fast they still are.
B A N N E D
1 Post
i met a guy a with a heavily modded gutted out vr4 gallant the other day. we were messin around and im almost certain he took off on me in 4th while i was in 2nd and still pulled about 4 cars. im sure its in the 11s for 1/4 mile
The 4G63 powered 91-92 USDM VR4 was rated at 195hp/203 lb-ft (a la 1G Eclipse GSX).
The latter gen 6A13TT powered VR4 (JDM) was rated at ~280hp. <---- That should have come stateside.
i am so smart S M R T
Originally Posted by 01clsstock
is that pic from a 3000gt?
Acura604
2G RDX Photograph Gallery
17
02-08-2021 03:32 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
09-25-2015 06:14 PM
