GM Synchro Lub for RSX
Old 04-17-2011, 05:53 PM
Indy04TL's Avatar
I know I am in the wrong place, but I looked in the RSX area and didn't find an answer, so I thought I would ask the experts. I asume the GM Synchro lub willl have the same positive results on the RSX 6/mt as it does on the TL mt.
Any feedback would be appreciated. Thanks.
Old 04-17-2011, 06:01 PM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
Absolutely. Many Honda cars are affected with the manual tranny issue, along with auto tranny issues. The Civic, RSX, and S2K are all affected. All of those can take the GM fluid, no problem.
Old 04-17-2011, 08:27 PM
NetDiver's Avatar
That's what I'm running in my RSX. I noticed slightly better shifts, and the second gear grind is almost gone.
Old 04-17-2011, 10:55 PM
the overexplainer
ez12a's Avatar
Think of it this way: Honda has basically only one type of MT fluid.
If honda uses one type of fluid in essentially all their MTs then Syncromesh would work.
Old 04-18-2011, 09:25 AM
sodaks2k's Avatar
I used syncromesh in my RSX-S and it was great.
Old 04-18-2011, 09:45 AM
Indy04TL's Avatar
I just stopped at a Chevy dealer to pick up some GM fluid and they needed to know "what kind of GM Synchro fluid" or a part #!! Anyone know which one? Thanks.
Old 04-18-2011, 09:57 AM
Indy04TL's Avatar
Found it--12377916. Does that sound right?
Old 04-18-2011, 10:08 AM
sodaks2k's Avatar
Yes that's the right part number.
If you NEED it then buy it locally then go ahead. Depending on how much they charge, you can save (quite a bit in my case) by ordering online. It comes out to $11.63/qt shipped from here.
https://acurazine.com/forums/showpos...8&postcount=22
Old 04-18-2011, 11:18 AM
Indy04TL's Avatar
sodaks2k, do you remember how much the rsx-s took for a change? The manual says 1.6 qts, but the Acura dealer is saying 2.3 qts? Thanks.
Old 04-18-2011, 01:51 PM
sodaks2k's Avatar
I'm pretty sure it's less than two.
cycdaniel
12-17-2019 10:58 AM
ITSJESTER
4G TL Photograph Gallery
10-13-2015 12:53 PM
darknite123
Integra
08-30-2015 03:00 PM
Quick Reply: GM Synchro Lub for RSX
