Glove Box Light
Old Apr 3, 2010 | 02:54 PM
GeezerB's Avatar
Glove Box Light
Can this light be accessed without removing the glove box? Mine is burnt out. I have a replacement LED. The service manual page only shows the housing, not how to get there.
I'm also assuming the assembly is on the right side? Can't tell by the scan.
Old Apr 3, 2010 | 02:57 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
The assembly is on the right side. I replaced mine but I don't remember how to get to it at the moment.
Old Apr 3, 2010 | 04:30 PM
robchimo's Avatar
pretty sure you have to remove the glove box to get at it. while your in there, replace the cabin air filter. then it wont seem like your doing all that work for a light.
Old Apr 3, 2010 | 04:37 PM
Good suggestion.
Old Apr 3, 2010 | 04:45 PM
Bearcat94's Avatar
AZ Community Team
No. But it is easier if you DROP the glove box, not remove it. Let it hang from it's hinges. Then:
Also, check the last post in this thread:
https://acurazine.com/forums/showthr...le#post8991779
Old Apr 3, 2010 | 05:32 PM
That's what I meant to say.
Old Apr 3, 2010 | 07:00 PM
GeezerB's Avatar
Thanks all, you guys are amazing. It's really quite simple.
There must be something wrong with my wiring. I replaced the bulb with 2 different new bulbs & no light. I even tried the old one in another socket & it worked. Is there a fuse for this circuit? I doubt it's a fuse as nothing else is not functioning. I remember the light working when I bought my TL about a year ago, as I referenced the manual often. I'm sure it has been out for a long time.
Old Apr 3, 2010 | 07:32 PM
dj5's Avatar
dj5
Headlights or parking lights need to be on for the glove box light to come on.
Old Apr 25, 2013 | 03:42 PM
rod1667's Avatar
6th Gear
What about the one in the middle console?
Old Apr 25, 2013 | 09:17 PM
Will Y.'s Avatar
Registered but harmless
Do you mean the light in the lower/larger armrest compartment?
If so, see post #30 in: https://acurazine.com/forums/3g-tl-2004-2008-93/g-058-removing-center-console-bulb-license-plate-bulbs-566648/.
That is one of the DIY threads in the 3G TL Service Dept/Garage thread, https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/, stickied on the home page of this section.
Welcome to AZ.
Old Sep 1, 2013 | 06:53 PM
Pitinzki's Avatar
6th Gear
Ahhh, this info really helps! Thanks.
Old Jul 1, 2020 | 01:12 PM
thefork's Avatar
Attachment 53797
Attachment 53798
I have it at this point, but how do you get the white cover off of it?
Old Jul 1, 2020 | 01:56 PM
you see the two friction mounts on either side? squeeze and pull or pry
oyayjoe
Jan 1, 2019 10:17 PM
sockr1
Oct 1, 2015 01:31 AM
Sep 14, 2015 10:09 PM
oyayjoe
Sep 12, 2015 04:40 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
