G-088: DIY: Clear Tail Light Mod
So, after seeing some members mod their Type S Tails I decided to give a try. I used a set of 04-06 tails and a set of 07-08 base tails. The process is pretty much the same as everyone else, cut the lights, take your time, be careful, take your time, and hope for the best.
Here are some pic of the process. I started with cutting a 06 tail around the sides and top just inside the plastic casing.
![Name: cutstopview.jpg
Size: 48.1 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/86152d1501791993-g-088-diy-clear-tail-light-mod-cutstopview.jpg)
![Name: cutssideview.jpg
Size: 39.2 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/86153d1501791993-g-088-diy-clear-tail-light-mod-cutssideview.jpg)
These cuts were made using a regular Dremel plastic cutting tool. I've found a thin cut version of the tool that's a little more precise than the regular tool (Sorry for the bad pic - still figuring out my camera).
![Name: dremmelthincut.jpg
Size: 28.2 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/86154d1501791993-g-088-diy-clear-tail-light-mod-dremmelthincut.jpg)
After removing the difusser and re-assembling the parts I decided to go with the clear-chrome setup. I left the difusser out because I wanted the red to "pop" a little more in the tails. We'll see!
![Name: finishedpair.jpg
Size: 56.2 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/86155d1501791993-g-088-diy-clear-tail-light-mod-finishedpair.jpg)
I think they turned out pretty good except for something I noticed on the right tail light!
![Name: rightcracked.jpg
Size: 50.6 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/86156d1501791993-g-088-diy-clear-tail-light-mod-rightcracked.jpg)
In the upper left hand corner the plastic is cracked! It must have happened when I tried to remove the original parts. Oh well. For now they will do. I'll have to order another set and redo the right side.
I hope to get these installed on my PMM soon. Since I've had my headlights cleared, the tails should look OK chromed out.
![](http://upit-downit.com/viewer2.php?file=nmow4rwb9ahjxspcuvj.jpg)
The following 3 users liked this post by BigTL:
added to the 3G garage!
From what I can tell, these are the AFTER photos judging by the way the jagged edges on the lense portion aren't matching the assembly which means the light sits more INSIDE the body instead of one flat surface due to the plastic grounded away on the lense and assembly. If that's the case, thing water will sit in that groove and eventually wash/eat/dissolve away whatever sealant you're using causing them to fog up (does it sound like I'm speaking from experience??) Definitely take some photos of them installed so we can get a better idea of how it looks. And a photo after splashing some water on there to check for puddling.
They are modified lights. I don't think the placement of the light will change since the screw connection inside the diffuser has not changed, just the space used for the cuts. This will be filled with Permatex Silicone which is rated for engine use.
Epoxy and silicone these back together. Keep in mind that this mod is much more of a pain than it seems.
If you want some custom tails done by someone with plenty of experience, then contact Acktl05. He is a vendor on these forums.
If you decide to do it yourself, then here is DIY that I did. Maybe it will help out a bit.
https://acurazine.com/forums/showthr...g+tails+voyage
Ha...so I'm the last guy to post and again revive it 8 months later...so I just bought a backup set of reds...so I can cut open my chipped and cracked set then...
I actually just bought the quick release set for my dremel....I'm sure it'll work just fine. I'll be careful not to crack. I have a practice set at least before I open up my ghost tails.
I was thinking about how to close them up to be water proof, I think i will end up using a few metal tabs and screws to strength and then just put some butyl tape around the seam I cut...that way, it'd be easy to reopen in the future if I ever change my mind.
Land of 10,000 lakes
I was thinking of doing the same thing with my taillights too. Idk about the screw and metal tabs though, our taillights sit pretty flush with the frame of the car all around. Maybe you could lay butyl in between the front and back, let that harden, the run a bead of clear silicone around it?
Maybe a thread title change to something that's easier to find and ALL encompassing like "DIY Tail Light Mod Cutting Open Tails 3G TL Acura"....I had a hard time finding this thread but here is my contribution
I'm sorry, but I reloaded my DIY page twice and lost the whole post so this one will be VERY quick.
Some lessons learned...
You can use butyl tape to seal up, like with headlights...
uninstall and reinstall the bezel starting/ending from the inner lower trunk corner of the light.
![Name: 20120916_110343.jpg
Size: 328.7 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/86158d1501791993-g-088-diy-clear-tail-light-mod-20120916_110343.jpg)
![Name: 20120916_114802.jpg
Size: 297.6 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/86159d1501791993-g-088-diy-clear-tail-light-mod-20120916_114802.jpg)
![Name: 20120916_121336.jpg
Size: 284.2 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/86160d1501791993-g-088-diy-clear-tail-light-mod-20120916_121336.jpg)
![Name: 20120916_121352.jpg
Size: 289.5 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/86161d1501791993-g-088-diy-clear-tail-light-mod-20120916_121352.jpg)
![Name: 20120916_144643.jpg
Size: 311.6 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/86162d1501791993-g-088-diy-clear-tail-light-mod-20120916_144643.jpg)
![Name: 20120916_145023.jpg
Size: 304.7 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/86163d1501791993-g-088-diy-clear-tail-light-mod-20120916_145023.jpg)
![Name: 20120916_150246.jpg
Size: 241.1 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/86164d1501791993-g-088-diy-clear-tail-light-mod-20120916_150246.jpg)
![Name: 20120916_150303.jpg
Size: 245.3 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/86165d1501791993-g-088-diy-clear-tail-light-mod-20120916_150303.jpg)
![Name: 20120916_150903.jpg
Size: 339.9 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/86166d1501791993-g-088-diy-clear-tail-light-mod-20120916_150903.jpg)
Here is my progress...
End result (copied from my progress thread post)
Ok, so I had a pretty productive weekend. Decided to tackle a few mods I'd been meaning to and one I DIDN'T.
Fixed my shock sensor, and finally finished sanding and polishing and sealing my headlights. Goodbye yellow tint in certain lighting!
http://www.flickr.com/photos/rockstar143/7993751951/http://www.flickr.com/photos/rockstar143/7993751951/ by http://www.flickr.com/people/rockstar143/, on Flickr
THEN, for some reason yesterday I decided that my type S tails in the attic, were never going to be back on the car with the chrome bezel, (and small corner chip)...so might as well give modding tails another shot. Overall...not too bad.
Check out my culmination of diy threads and hopeful garage entries.
https://acurazine.com/forums/showthr...=618762&page=4
Also a little DIY from other members on how to make it EASY to swap tails in the future.
https://acurazine.com/forums/showthr...8#post14040738
Here are my end results
What I did was:
NPB color matched bezel
CF wrap on reflector
removed frosted lens
sealed back up with butyl tape
http://www.flickr.com/photos/rockstar143/7993773380/http://www.flickr.com/photos/rockstar143/7993773380/ by http://www.flickr.com/people/rockstar143/, on Flickr
OLD USR Smoked WITH frosted lens in place
http://www.flickr.com/photos/rockstar143/7993772260/http://www.flickr.com/photos/rockstar143/7993772260/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/7993770584/http://www.flickr.com/photos/rockstar143/7993770584/ by http://www.flickr.com/people/rockstar143/, on Flickr
New OEM modded Type S tails with NO frost in place
http://www.flickr.com/photos/rockstar143/7993764711/http://www.flickr.com/photos/rockstar143/7993764711/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/7993771124/http://www.flickr.com/photos/rockstar143/7993771124/ by http://www.flickr.com/people/rockstar143/, on Flickr
comparison
http://www.flickr.com/photos/rockstar143/7993763783/http://www.flickr.com/photos/rockstar143/7993763783/ by http://www.flickr.com/people/rockstar143/, on Flickr
and just some other shots from my favorite place to shoot
http://www.flickr.com/photos/rockstar143/7993761913/http://www.flickr.com/photos/rockstar143/7993761913/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/7993769072/http://www.flickr.com/photos/rockstar143/7993769072/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/7993760133/http://www.flickr.com/photos/rockstar143/7993760133/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/7993767220/http://www.flickr.com/photos/rockstar143/7993767220/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/7993758191/http://www.flickr.com/photos/rockstar143/7993758191/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/7993757441/http://www.flickr.com/photos/rockstar143/7993757441/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/7993756533/http://www.flickr.com/photos/rockstar143/7993756533/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/7993755491/http://www.flickr.com/photos/rockstar143/7993755491/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/7993762804/http://www.flickr.com/photos/rockstar143/7993762804/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/7993759672/http://www.flickr.com/photos/rockstar143/7993759672/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/7993761752/http://www.flickr.com/photos/rockstar143/7993761752/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/7993752659/http://www.flickr.com/photos/rockstar143/7993752659/ by http://www.flickr.com/people/rockstar143/, on Flickr
What I did was:
comparison
The following 7 users liked this post by rockstar143:
Bearcat94 (10-21-2012),
EvilVirus (09-17-2012),
Healingduck (09-17-2012),
MEKO (11-11-2013),
nvasion (09-16-2012),
and 2 others liked this post.
rockstar143 (09-16-2012)
rockstar143 (09-17-2012)
for a more comprehensive thread on WHERE TO CUT, see here:
page 2, mainly
https://acurazine.com/forums/showt...ail+lights+mod
page 2, mainly
Soooo fucking legit dude!! Props!
When my lease is up I'll definitely be cutting into my tail lights and clear out my head lights as well.
Just buy another set like I did. I currently have 05 base tails on the car now, which will eventually get chopped up to get the clear brake and turn signal lenses out.
I saw it asked earlier..well kind of, about needing to have a set of 04-06 and 07-08 to do the mods and response was it depends on what you are doing. Is there a tail light mod for the 06 all reds that doesnt involve buying another of set of tail. like JUST modding the 06? ive looked everywhere and all i see are mods using 07-08 tails also.
Depends on if you are looking to have a red outer lens or a clear outer lens. If you're looking to do any internal modding than I would suggest a clear outer lens which can only be used with 07-08 Base or Type S taillights.
It all depends on what kind of look you're trying to achieve with the taillights.
![](http://farm6.staticflickr.com/5470/9582798041_2cc12ffb05_b.jpg)
TL_Trell (10-30-2013)
^That's what I did.
