Fujita CAI??
Fujita CAI??
Hey guys whats up? I'm thinking of buying a used Fujita CAI off another Aziner for $125. Seller says its in good condition a few scuffs. My questions are, how hard was it to install and remove ( when i take it in for warranty work), power gains, etc...do you reccomend this CAI..thanks guys
Help need ASAP i don't want to keep this guy on the hook and end up not buying it from him. thanks!!!!!!
Unshunned
I can't tell you if $125 is fair or not, but I can recommend the Fujita. It's easy to install - bolts right on + 1 mounting screw, the hardest part is removing your old intake tubes IMO. You're not going to want to remove it for warranty work every time you take it in - that will be a huge PIA. I've taken mine in for the power steering hose recall and they didn't say a word about it. Sound is good on WOT, but a bit annoying with some whistle at around 2000 rpm cruising through the subdivision. I noticed a couple more MPG's on highway and a couple more overall on my average MPG according to the computer. I'd say go for it
A-spec steering wheel ftw
if you plan on adding the TB spacers you might want to reconsider, over time the added length from your TB will stress the mounting bracket. if you don't plan on adding the spacers then you should be fine. I loved the Fujita
Here's a link to how to uninstall your OEM intake and install the new cold air. Have fun! ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
https://acurazine.com/forums/3g-tl-2004-2008-93/diy-video-uninstalling-oem-intake-installing-cold-air-intake-3g-garage-b-001-a-628372/
lanechanger
10-13-2015 10:56 AM
