Fuel Tank Capacity for 04?
So the owner's manual says 17 gal.
I've never been able to pump more than 14 gal into it. Last week I ran it for 45 miles with the low fuel light on. Computer said 0 miles to empty...barely squeezed 14 gallons into it.
Short of pulling a Kramer, how do I figure out what the real capacity of the tank is?
The owner's manual is correct. Once the MID gets to 0, you still have 3 gallons in the tank. If you do a search or even look in the 3G Garage, there are tons of threads on this topic.
The lowest I have had it was 5 miles to empty and I hated the idea of having the fuel that low.
Registered Member
It's 17.1 gallons. When the low fuel light comes on, you have around 3 gallons remaining in your tank.
I have an '04 manual and an '05 automatic.
https://acurazine.com/forums/3g-tl-2004-2008-93/miles-empty-553475/
https://acurazine.com/forums/3g-tl-2004-2008-93/fuel-tank-capacity-observations-544346/
https://acurazine.com/forums/3g-tl-2004-2008-93/car-has-only-14-g-tank-554838/
https://acurazine.com/forums/3g-tl-2004-2008-93/check-fuel-cap-instead-low-fuel-warning-567240/
The above are all from the 3G Garage. You must have missed it.
Its amazing what kind of info can be found in the owner manual- more correctly called the Operations Manual
every system is gone thru from step 1
Learn why there are 2 noises when you start to move the car~
joflewbyu2
08-18-2019 10:38 PM
ExcelerateRep
10-14-2015 08:20 AM
joflewbyu2
10-08-2015 11:16 AM
