Fuel Tank
Old Oct 17, 2004 | 03:24 PM
hcg_miami's Avatar
Fuel Tank
My manual says that the fuel tank on the 2004 TL hold 17.09 gallons. I get about 13 gallons in max when the empty tank light comes on. Does that mean there's still some 4 gallons in reserve?
I get about 200 miles before I need to get gas, whereas on my Bimmer I had easily 340 miles with same fuel tank capacity.
Thanks,
HCG....
Old Oct 17, 2004 | 03:35 PM
Road Rage's Avatar
Not a Blowhole
Short answer? Yes.
This question has been asked and answered a zillion times. Check in 3G Garage in the stickies if you want more detail. Many mfrs do this, because owners squawk at the car company rather than themselves when they run out of gas. It is an example of cognitive dissonance taken to the extremes as we do here in the US - something bad happens, it is always someone else's fault. So Acura, like may others, adds a huge buffer between when the light comes on, and when the car is actually out of fuel. You are better off not letting the fuel get very low anyway.
Old Oct 17, 2004 | 03:37 PM
Ron A's Avatar
Administrator
FROM THE 3G GARAGE:
Miles to Empty & Low Fuel Warning
http://www.acura-tl.com/forums/showthread.php?t=86945
http://www.acura-tl.com/forums/showthread.php?t=84730
http://www.acura-tl.com/forums/showthread.php?t=71425
Old Oct 17, 2004 | 03:43 PM
Road Rage's Avatar
Not a Blowhole
RTFM! (I could not resist - my fingers were powerless as the Dark Side won over).
Old Oct 17, 2004 | 04:05 PM
Ron A's Avatar
Administrator
Reference please
I couldn't resist either
Old Oct 17, 2004 | 04:52 PM
oppnyc's Avatar
Thanks,
HCG....
Just yesterday I was able to put 17.05 gallong of gas.
But pump stops at about 13-14 gallongs, however you just keep pumping and pumping and you will make it 17 gallong if your tank is really empty.
Old Oct 17, 2004 | 06:17 PM
ayethetiense's Avatar
.:KCCO:.
hcg miami needs help... can some PLEASE tell em about the search feature that we have on the forums.
THANKS!
Old Oct 17, 2004 | 06:25 PM
Brewmaster's Avatar
I'm Baaack!
Then you look at the ground and wonder what the puddle is ... hmmm maybe light a match to add some light to the subject .. bend down to see exactly what it is that's leaking from your car and ........
Good plan
joflewbyu2
Aug 18, 2019 10:38 PM
LeVeL
Oct 18, 2015 04:19 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
joflewbyu2
Oct 8, 2015 11:16 AM
