Fuel Line Cleaner
Fuel Line Cleaner
TODAY AT THE MOBIL Oil station they recommended me to get my fuels cleaned. They said I due for that service. I said ok. They hooked this container with green solution inside with a tube connected to it. Took my fuel line from my engine and plugged the two lines together. Then told me to turn my car on and he kept my car idling at 2500 rps. My car was draining the liquid from the bottle. After all the liquid was gone, he reved my car higher. My cars exhaust started spitting out white smoke. The mechanic said that was the contaminents that built up in my engine. This cost me $54.00. Im wondering now was that neccessary and is a fuel cleaner that you pour in the gas tank sufficent? Thanks for the responses.
The white smoke was not the contaminants, it was whatever those jokers ran through your fuels system burning off. This is not an Acura recommended service and is something that probably shouldn't need to be done unless you are having fuel system problems.
Bottom line... you're out $54 bucks and your car doesn't have the slightest clue what happened.
What those f$%kers ripped me off. Hmmmm. My car did have a slight hesitation when I accelerated my car. It doesn't exist anymore. But you guys think that wa worthless. That really sucks.
Your car is what about 15 months old? And you had a hesitation? Premium gas typically comes from the same place regardless of what station you buy it. Yes, I hear some companies might have some different additives. But aside from fuel injector cleaner in your gas tank I have never known anyone to need the 54 dollar service that you had ..
Oh well. I am out of $54 dollars. Never again I'm getting that. How often must we replace our Transmission fluid?
it should be in the manual. i would do it every 10,000 miles, but i still follow the 3000 mile oil change intervals..see what other people on this forum has to say about it.
I heard somewhere the reason for changing the tranny fluid so often was because there is no filter in the system.
Originally Posted by fasttl
SUCKER!
Sorry, I'm not laughing at you, WDP. Just at that thoughtful comment.
The general rule, which you really should've learned at the age of 26 (unless, of course, you just started driving for whatever reason, and this is your first car), is that you decline the "recommended service" these shops offer (at a special discount good for today only - lucky you!). Since these grease monkeys suck at sales pitch, a simple "no" would do. Just remember what the recommended services were and cross reference your manual, the owners on this forum, and/or the Acura dealership.
I think most would agree with me on BITOG that "shocking" the fuel system with a cleaning periodically or "shocking" it with a bottle of Techron periodically does little good since it wouldn't keep the fuel system clean, continuously.
Thus, I recommend using a fuel system cleaner such as FP60 at every fill-up, to keep the fuel system clean and to reduce nox levels, insolubles, and improve combustion efficiency.
It is MUCH cheaper than paying a grease monkey $50+ to clean the system.
As for ATF, drain/refill for the first time at <10K to remove the break-in debris. Then, drain/refill every 10-15K thereafter, as the TL does not have a serviceable filter. A disposable magnefine in-line tranny filter is a good investment, but it may be wise to wait until you're out of warranty.
Michael
Michael
MrHeeltoe
20
02-23-2023 01:54 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
