Found the most inaccessible bolt in the car!
Old Apr 28, 2008 | 06:46 PM
SRT-11's Avatar
Quiet, Rika Neenja!
And it only took Forever! it's the drain bolt from step 4 below. a 90 pound contortionist slathered in vasoline couldn't get to that thing!
(it will be possible with some clever jacking and a box wrench, but GEEZ that is the least convenient thing I've ever seen. looks like the coolant drain will wait until tomorrow, it's about beer:30
Old Apr 29, 2008 | 11:57 AM
KaMLuNg's Avatar
won't work even with extensions???
Old Apr 29, 2008 | 12:07 PM
Fulani has a TL's Avatar
What year is your car that it already requires a coolant flush?
Old Apr 29, 2008 | 01:24 PM
01tl4tl's Avatar
Coolant is really only good for 5 years, then the stuff inside it starts to go acidic.
That bolt is not accessable until you scrape away 3 layers of skin from hand-
then right in~
At least your manual said to put a hose on it!
Some are a butterfly valve- some a bolt- some maybe a bolt with drain port,,,,,
Old Apr 29, 2008 | 02:32 PM
SRT-11's Avatar
Quiet, Rika Neenja!
I might be able to get at it with a box wrench. gonna be a pain no matter what though. I have an 04, but I bought it used so I'm changing out all the fluids
Old Apr 29, 2008 | 02:34 PM
SRT-11's Avatar
Quiet, Rika Neenja!
anyone know the proper way to bleed air out of our system? I've heard horror stories about air bubbles in these things...
Old Apr 29, 2008 | 02:36 PM
I wasnt sure, cuz it shows you joined in dec. of 07, so I was thinking you had an 07, thats why I was thinking to myself on why you changing the fluids in less than a year.
Old Apr 29, 2008 | 02:37 PM
then right in~
yeah, I usually change fluids out after the first 5 years, then every 3 after that... Gotta wear some gloves, saved me numerous times, except difficult to grab onto the smaller nuts/bolts/screws.....
Old Apr 29, 2008 | 05:28 PM
01tl4tl's Avatar
The owner book gives the specific procedure- it involves engine running with heat on and rad cap on off open- fans running for x time then the next step....
here is the free download or view online
click year then model
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
Old Apr 29, 2008 | 05:39 PM
erick3's Avatar
exactly my question
Old Apr 30, 2008 | 07:37 AM
SRT-11's Avatar
Quiet, Rika Neenja!
well I got at it, I have the narfed up forearms to prove it. not too bad in the end, just jack up the passenger side, take off the passenger (front obviously) wheel, look up in there, find the nippled bolt, use a little socket wrench with a 12mm socket on it to just crack it loose (and then you can turn it by hand), put a 1/4" ID, 3 foot long rubber hose on it, and rotate it counterclockwise, it should drain with no problemo.
james357
Feb 13, 2016 02:37 PM
MyKids&Cars
Oct 13, 2015 11:44 PM
lland
Oct 4, 2015 04:47 PM
DUECE_DXJ
Sep 24, 2015 04:54 PM
voigt
Sep 2, 2015 10:44 PM
