Fogs as DRL's
Old Aug 23, 2008 | 10:52 PM
ATLTypeS's Avatar
Fogs as DRL's
Has anyone modded their fog lights to come on instead of the DRL's. I noticed on the new MDX's the DRL's are down in the fog housing and it looks really cool. I would like to do the same thing on my TL-S. Or maybe even just mod the fogs to turn on without turning on the headlights. Has anyone done anything similar yet that can help me out?
Old Aug 24, 2008 | 08:08 PM
ATLTypeS's Avatar
Anyone?
Old Aug 26, 2008 | 02:37 PM
ATLTypeS's Avatar
I guess this is not possible since no one has responded...oh well.
Old Aug 26, 2008 | 02:45 PM
TeknoKing's Avatar
It will be easier for you to get aftermarket foggies with a switch to do this mod.
Stock foglights all run thru a computer, which unfortunately is not easy (or fun) to mess with as you will get warning lights.
Old Sep 3, 2008 | 09:56 AM
sk8ter4life's Avatar
Stickr Mstr
Smile
I have a 04 model, which does not have DRL. I want the foglights to come on by themself. (gives it a mean look)
I was thinking the same thing this morning. Since I have the Yellow bulbs, I want them on by themself, vs only on w/ the head lights. You can barely see the Yellow, since the Main HID headlights sort of blends and washes out the yellowness.
In order to sucessfully do this, you have a few choices
  • rewire the foglight wires to a separate switch
  • or something simplier, reroute the power wire on the fogs and use exisiting switch
It may sound confusing, I am going to check on the schematic and hopefully have a writeup on this =D
Old Oct 5, 2008 | 12:59 AM
Bonestock TL-S's Avatar
ive been thinkin bout it too....so if u find a way let me know
Old Oct 5, 2008 | 01:10 AM
Blazing GT's Avatar
Yes it is possible:
https://acurazine.com/forums/3g-tl-photograph-gallery-96/base-tl-type-s-fusion-hqtl-presents-subtle-aggression-56k-go-vacation-683614/
Old Oct 5, 2008 | 02:51 AM
SQAcuraTL04's Avatar
Here you go man. I will be doing this in the near future as well.
https://acurazine.com/forums/3g-tl-2004-2008-93/diy-installation-daytime-running-lights%2A%2A-detailed-pictures%2A%2A-3g-garage-g-067-a-596398/
Old Oct 5, 2008 | 09:49 AM
ATLTypeS's Avatar
Neither of those links are what I had in mind but thanks for them anyway. I have an 08 Type S so it has the factory fogs already I was wondering about rerouting the wiring from the drl down to the fog and disabling the factory drl all together. I may play around with some idea's next weekend when I put in my Hoen Endurance bulbs in my fogs.
Old Oct 5, 2008 | 04:45 PM
rockyfeller's Avatar
King of NYC
You can do some automobile surgery and do a simple swap:
1) Take off your front bumper and headlights to get free access to all the wiring.
2) Unplug your DRLs and chop off the bulb harnesses (the bulb holders) with about 2" of slack. Extend these wires and reroute them down towards your fogs. Use wire loom and zip-ties as necessary.
3)Unplug your fogs and chop off the harnesses just like above. Reroute those wires back up to your DRLs.
4) Now splice the fog harness on the DRL wiring and the DRL harness on the fog wiring and put the bulbs back in.
So what you have here are lower fogs that will behave like DRLs and the place where your DRLs were can be fogs that come on at will whenever you hit your fog-light switch. Those can be kept off of course or you can even skip that step if you don't want them like you said. Just disconnect them and insulate them REALLY well and out of the way. My advise is that you might want to keep them connected though because I think you may get a "bulb out" warning on the dash; you can't mess with the fuse either.
Old Oct 5, 2008 | 04:53 PM
ATLTypeS's Avatar
I was thinking about slicing the wiring from the drl down into the fog wiring, and leaving the fogs hooked up as normal so they will get the power from the drl during the day and then at night i can turn them on/off as fogs like normal operation. Not sure if this is gonna work though....
Old Oct 5, 2008 | 11:51 PM
John V's Avatar
DRL's
Last month I turned my 06's fog lights into DRL's. It was a very simple task. Now as soon as i turn the car on the fog lights come on and when I turn the parking lights or head lights on the DRL's turn off and the fog lights work as normal operation. Here is the web site; http://www.daytime-running-lights.co...ight_DRLs.html
I bought the DRL-2007 FLX. At 85 dollars it was worth a try and I am very pleased with it.
Old Oct 6, 2008 | 12:15 AM
King of NYC
DO NOT TRY what you just said...not a good idea! In theory you can have it work the way you said, ask someone who is good with wiring and they will wire in a relay for you. Just don't wire it direct like that!
Old Oct 6, 2008 | 12:17 AM
King of NYC
Yes, many of us have it that way too, but that is not what he is asking about. He wants it differently.
Old Oct 6, 2008 | 08:06 AM
ATLTypeS's Avatar
yeah, I have an 08..I want hte fogs down in the lower grill to act as drl instead of the drl up in the headlight housing. I want to disable that drl all togeather.
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Avenger411
Oct 11, 2015 03:53 PM
rockyboy
Sep 29, 2015 12:05 AM
rhdune16
Sep 28, 2015 11:31 AM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
