Fogs
Old May 8, 2007 | 02:08 PM
HoustonsTL's Avatar
WDP FTW
Fogs
is there a way were u can turn the fogs on, in an 05 with out turning on the headlights?
Old May 8, 2007 | 09:00 PM
rockyfeller's Avatar
King of NYC
You need to wire in a switch with a relay or you can also do this how I've done it; with a DRL module. Do a search all this has been discussed.
Old May 9, 2007 | 09:02 AM
BAD DNKY's Avatar
you need to find out which wire is running from the fogs to the remote headlight wire (remote meaning that your headlight switch is making the wire hot) Disconnect this wire and install a switch hooked up to the fuse panel to a wire that is always hot. Good luck with the install. Once you find the wire its a peice of cake!
Old May 9, 2007 | 12:36 PM
HoustonsTL's Avatar
WDP FTW
thanks for the info
Old May 9, 2007 | 01:51 PM
johnny--2k's Avatar
My Daily Driver
YES!!!!
You dont need a switch unless you want to control them separately. Mine are on as long as the parking lights are on, so I can basically never turn them off with the headlights. If I want to turn them off, i can wire in a switch to have separate control of them.
Here is a short write-up....
Buy a relay from autozone, get some wire if you dont have any, you will need to get to one of the parking light connectors, preferably by the drivers side near the battery, and the drivers side fog light connector. You will need new wire because you are basically splicing into current wires on the fog and parking lights. I just used those little t taps.....
Run one wire with an in-line fuse from the positive battery post to post 30 on the relay.
Run another wire from any ground to post 85 on the relay.
Run a third wire from the positive wire on the parking light connector to post 86 on the relay. Be careful here, there is one black wire and two red wires. One is for the parking light and one is for the turn signal. The one for the parking light is the one on the end of the connector.
Run the fourth wire from the positive side of the fog light connector to post 87 of the relay. The positive on the fog light is the blue/yellow one.
If you want a switch, it would be run from the parking light wire hooked to post 86 to basically interrupt the flow of current through there.
Hope that helps you.....
Here are some pics to persuade you as well....
Old May 10, 2007 | 12:53 AM
HoustonsTL's Avatar
WDP FTW
thanks for the info bro ima try to do it this weekend.
Old May 10, 2007 | 08:26 AM
johnny--2k's Avatar
My Daily Driver
no problem. let me know if you run into any snags.....
should be pretty straight forward though. Just take your time.
Avenger411
Oct 11, 2015 03:53 PM
rockyboy
Sep 29, 2015 12:05 AM
rhdune16
Sep 28, 2015 11:31 AM
h22lude
Sep 27, 2015 06:22 PM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
