Fluid agains
what are you trying to do?
for the PSF...just get a turkey baster and take out the old fluid in the res, then refill with the amsoil. one bottle should be fine. there is really no need to fully drain the system.
if you want to bleed your brake fluid, get 3-4 500ML bottles of motul 5.1
unfortunately, both these items are usually only available online. ebay/amazon/etc...i've never found them in a local store.
+1 to AMSOIL. I use AMSOIL for ALL of my fluids. I have found 3 bottles of PS are needed for a 100% changeover...most usually need only 26fl oz., but mine required about 2.5 bottles. Brake fluid, I'd also recommend 3, but you'll likely only need 2.
SidhuSaaB
05-30-2020 12:40 AM
