First Oil Change, Need Tips/advice
So I picked up my 57k mile 04 Acura TL. My cousin is my mechanic, he is awesome.
So he tells me I need to bring, 5 quartz and he recommended Valvoline Oil, 5W30.
A bit about me, I dont want to use Synthetic Oil, and I will love to change the oil every 3k or 3 months. None of that 5 months 5k mile things. I am a city driver, I only take my cars on the highways if I really have to. SO take that into consideration.
That being said, which Valvoline Oil should I buy, or is there something better? I am up for suggestions. Oh and which Oil Filter should I get? Thanks. I am going to buy it either at Autozone, Walmart, Target.
Whatever you do, just stay away from Fram filters.
fully synthetic is fine- or regular dinosuar oil- any name brand is fine 5-30 is correct
Change before 5000 miles even in city driving- is just adding to the waste oil problem
Seafoam the oil before change and get the sludge out of the engine
Seafoam the intake and gas tank per DIY for best performance from your car
The honda filter should be good, and regular dino oil should be good as well. Honestly, you are going to be wasting money if you do the 3K 3month routine. Follow the MID on what services to do, it uses extremely high tech and complicated algorythims and data to determine when to get it changed.
Discussing motor oil is sorta like discussing religion.
My personal preference is Castrol GTX (dino) or Syntec (full synthetic) with the OEM Honda filter. I prefer the A01 made by Filtec but it seems the A02 made by Fram is all that's available.
Use the MID as a guide, but I try not to let it go below 30% before changing, mostly to prevent varnish and sludge buildup.
Follow the MID. I use Mobil 1, but any oil that meets the manufactures spec will do the job.
For the filter I use the Honda S-2000 version which is a little bit bigger then the Acura filter.
Generally get a Mobil 1 filter M1-104.
Originally Posted by eluzion
How long does it take for the MID to indicate 0%? 10k miles?
it depends on what type of oil you have. if you have synthetic it would be longer, if you have regular oil it would of coarse be faster.
Originally Posted by MinDawg
Hmm...is my TL the only one with cap that says 5W-20 ?
Ok...so I'm not crazy after all
5W-20 IS the recommended oil grade for this engine and is all I use.
I'd go synthetic regardless.
Originally Posted by princelybug
lol, +1. 5W-30 is fine, and 5W-20 is fine. However, 5W-20 is what's recommended by the manufacturer.
As for what I bought today at Walmart.
I bought 5 Quart container of 5w-30 Valvoline Premium Conventional Oil, I see you guys call this Dino Oil??? I got that, and I was a tad confused when I was looking through the car book at walmart for oil filters for my make and model. I saw only fram filters, And I knew to get away from that. Not until I tried to read the edge which was almost not visible, I found a Mobil filter, It is M1-110. So yea.. I picked that up.
mada51589
05-03-2022 08:54 PM
HydrasunGQ
09-14-2015 10:14 PM
