Feeling a bit dumb I cant find the IAC valve
Old May 15, 2010 | 09:00 AM
endlessmind's Avatar
8th Gear
Ive searched the fsm went to myacura to look at the visuals to get an idea shit they dont even sell an replacement but I know there is one Ive cleaned them in several cars and now I got a grumpy idle and cleaning the throttle body wasnt good enough?
Old May 15, 2010 | 09:41 AM
nfnsquared's Avatar
I'd check and blow out the EGR valve with compressed air first. Many folks here have had it get plugged up causing a rough idle. Do a search, there are a couple of threads on fixing a rough idle by blowing out/replacing the EGR valve.
The IAC is only mentioned on one page in the SM, pg 9-3. But it doesn't really indicate where it is....somewhere under the intake manifold cover.
Old May 15, 2010 | 09:45 AM
8th Gear
nevermind thx tho I jus hit the searches for the second gens and its under the throttle body there was a better visual that they had that we dont in our sm... but thx on that will get to that as well...
Old May 15, 2010 | 12:42 PM
01tl4tl's Avatar
remove TB assembly- flip over and remove 2 screws from round cover- remove disc inside and use carb cleaner (based on gen2)
get a new gasket for tb to manifold
seafoam the gas and manifold
egr ports get plugged bad every 75kmiles (based on my gen2) must remove manifold and use carb cleaner plus wire hanger to clean them- amazing differance after
IAC dirty often makes surge rpm when stopped
ck a spark plug-over 60kmiles they are ready for new ngk irids- same as it came with is the best plug for the job
Old May 15, 2010 | 03:19 PM
I hate cars's Avatar
If the 3rd gen TL uses an IAC valve it would be the first DBW car that I've ever seen use it. With the computer in control of the throttle valve instead of a cable and your foot, it eliminates the need for the IAC valve.
Old May 15, 2010 | 07:33 PM
nfnsquared's Avatar
Yeah, I dunno....This is the one and only reference in the 04 SM. I was surprised to find it there.....
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
PortlandRL
Sep 14, 2015 12:01 PM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
