Factory brembos on auto
Yes, there are tons of threads on this.
people have done the conversion, but like VQ said...its a lot cheaper to go aftermarket BBK. (Big Brake Kit.)
search around.
TL-S Brembo swap part list:
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/d-103-tl-s-brembo-swap-parts-list-716463/
A thread convincing the OP to go aftermarket:
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/standard-brakes-brembos-626058/
search around.
Veni, vidi, vici
aftermarket is better, and from what I hear from car & driver and other reputable sources, you're only really buying the name brand, the quality and performance of brembos are as good as OEM.
not that easy, it is a little more complex to do a full big brake job.
there are many parts involved and not just the calipers, rotors and pads. there are also the caliper holders. also the rotors are based on wheel diameter. if you are using 17 inch mags then the rotors are smaller in diameter to fit the 17 inch mag. the larger the diameter of the mag the bigger the rotor. there are many kits out there other than brembo. you are looking at around 2000 for the front alone.
AZ Community Team
Received 7,771 Likes
search around.
https://acurazine.com/forums/showthread.php?t=716463
https://acurazine.com/forums/showthread.php?t=626058
search around.
OP we just did this recently. Please use the links posted here and if you have additional questions/comments post them here: https://acurazine.com/forums/3g-tl-2004-2008-93/type-s-brembo-brakes-791861/
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
