Ethanol
Old Apr 27, 2014 | 11:05 PM
1black_seven's Avatar
Slot Machine Lubricator
Ethanol
Opinions about ethanol? Does anyone here avoid E-gas or stations that use E10?
I've heard mixed opinions about it including reduced MPG and reduced horse power.
Old Apr 28, 2014 | 05:27 AM
^most of our gas has it. most of us are losing MPG and horse power.
well known topic, that people get fired up over because the damn corn lobbyist.
Old Apr 28, 2014 | 06:44 AM
JTS97Z28's Avatar
People can still avoid gas with ethanol? I haven't seen an ethanol free fuel here around Chicago in atleast a decade.
I'm not too worried about it. My car seems to pull nicely through all gears, and last tank I averaged 25mpg without ever touching a highway. Can't argue too much about that :-)
Old Apr 28, 2014 | 07:34 AM
Vlad_Type_S's Avatar
Registered Bike Offender
Avoid it if you can. I used to run pure 91 when I lived in Wisconsin. Now I run E10 93 in Chicago. I noticed a 2-3 mpg drop (manually calculated) on the highway.
You can use this site to see if there are any pumps near you. Otherwise you've gotta live with what you've got.
http://pure-gas.org/
Old Apr 28, 2014 | 08:32 AM
98vtec's Avatar
i've never had a problem with e10. But I like the chemical property advantages of ethanol so eh.
Old Apr 28, 2014 | 10:19 AM
nttstt444's Avatar
If I had the option id get ethanol free but I haven't seen it around here in a long time.
Old Apr 28, 2014 | 10:58 AM
mvp2765's Avatar
I used to get it in Green Bay when i went to school up there. It's now no where to be found in Chicago.
Old Apr 28, 2014 | 11:45 AM
MarcoNorthPolo's Avatar
KCCO
Around here regular and mid grade have up to 10% ethanol, but premium doesn't have any. At least I don't have to worry about it.
Old Apr 28, 2014 | 12:46 PM
bla8291's Avatar
A lot of the listings on there are for marinas. There is one just down the street from me. Is this website implying that it would be no problem pulling up and refueling there? I would assume they'd prevent me from doing so.
Old Apr 28, 2014 | 01:00 PM
erdoc48's Avatar
06 Anthracite TL
Just be careful if they ever sell E15 and make sure you don't use it (there was conjecture about bringing it to market but it never really took off). As for E10, it's all that's available here in NJ- as far as I know, there's no 'pure gas' stations here.
Old Apr 28, 2014 | 03:06 PM
Turbonut's Avatar
Ethanol 10% E10 will yield a slight decrease in mpg, stated 2-3% but ethanol in itself is @ 115 octane. The oxygen content is what reduces the emissions and will better clean the fuel system and as it has a higher octane there should be no performance problems. Only problem with the E10 is that it attracts moisture and separation can occur, but in automobiles most don't experience this, at least I haven't and the cars sit for months, but not good for older carb vehicles, esp. one that sits.
Just remember that 10% is the max, but in reality the blend differs greatly as there is no mandatory testing, probably between 9-10% at this time.
Old Apr 28, 2014 | 03:48 PM
thisaznboi88's Avatar
F it and run e85. You lose mpg but gain power if you can tune it. You also need larger injectors
Old Apr 28, 2014 | 04:23 PM
I found this on another forum discussing the same topic.
I don't know what it means but he used big words and math equations so it must be right.
"Straight gasoline has 114k BTU per gallon. Straight ethanol has 76k BTU per gallon, a 90/10 mixture would have approximataly 110k BTU per gallon (114k * 0.9 + 76k * 0.1). The E10 gasoline gallon equivalent 1.036 (114k/110k = 1.036). Basically, your engine will produce 3.4 percent less power per power stroke on E10 than it would on straight gasoline because there is 3.4 percent less energy in the same quantity of fuel. To make the same power per stroke would require 1.036 times more fuel induced into the combustion chamber."
Old Apr 28, 2014 | 04:38 PM
nfnsquared's Avatar
For me, there's been no measurable difference in MPG running E10 nor can my "butt dyno" tell a difference....
I sure am glad someone started a thread on this since it's never been discussed before.
Old Apr 28, 2014 | 05:40 PM
It was discussed in the TSX section not the 3G discussion. Even still, not everyone in this forum has been on here since 2003.
Old Apr 28, 2014 | 05:56 PM
Originally Posted by losiglow
This conversation is old hat , but it's fun to talk about anyway. It's this easy:
1st - Yes, many have experienced this phenomenon, that is, a consistent 10% decrease in MPG from the 10% etOH in gasoline. From a chemical standpoint, etOH contains only a fraction of the energy that is found is gasoline. Therefore, via simply chemistry, you're going to suffer an equal mileage loss equivilant to the reduced energy potential from added etOH. Usually it's less than 10% since etOH contains some energy (just not nearly as much as gasoline). So while it burns much cleaner than gasoline, you're simply having to use more gasoline to get the same result yielding no actual pollution reduction.
2nd - The reason etOh is in gasoline is NOT because it's somehow better for the environment. After accounting for milage loss, we're breaking even (actually, not even that, see "3rd"). etOH is in gasoline because of the ethanol/corn lobby convincing the government to add it.
3rd - Adding etOH is actually worse for the environment because of the energy (in the form of fossil fuels - coal and oil) required to manufacture ethanol.
It's a lose/lose for the american consumer but a great way for government lobbiests to line their pockets. It's a steaming pile of horse
Originally Posted by I hate cars
Agreed. As usual, a small group of people get rich, we all pay the price, it's the new American way.
Ethanol has about 1/2 the energy content of gasoline so you have to burn twice as much to get the same power. Or said another way you get 1/2 the mpg. The plus is it's led to huge OEM fuel injectors. In the old days, injectors capable of supporting 800hp with only 6 of them idled terribly and had bad street manners; they were not linear through their flow range and did not like the super short pulsewidth required at idle.
Now we have large injectors as OEM equipment on many flex fuel cars that have great street manners and are used as aftermarket injectors on many high hp gasoline engines. Many flex fuel cars also have huge gas tanks which is nice when you run it on gasoline. Some of our work vehicles have 35 gallon tanks where they used to hold 22-ish gallons.
But yeah, if the car has not been optimized for this fuel, mileage sucks. If these a**holes did not lower the octane of the gasoline mixed with ethanol we would have higher octane with 10% ethanol but of course they use a lower octane gasoline and bring the octane back up with the ethanol mix. The ECU would see little to no knock retard and it would advance timing slightly, making up for part of the mpg loss but that's too much to ask for.
As is typical for the government, they do a piss poor job of "research", not that they actually care about what's better for us or the environment. Sure, the ethanol mix is ever so slightly cleaner through the tailpipe which is the selling point to the general public. However, you're burning a larger volume of it due to the lower BTU content. It also takes a ton of hydrocarbon fuel to produce Ethanol. In the end it's worse for the environment but hey, it's cleaner out the tailpipe and leaving out all of the other facts makes it easy to sell to the public. Kind of like electric cars. They have "zero emissions". I guess that's true, the car puts out no emissions.... but the coal burning power plant 100 miles away that supplied the energy puts out a whole hell of a lot more pollutants than a modern ULEV or PZEV car does for the same power.
My TL with the 3rd cat removed had it's first official smog test which is it's second test. The first one when it had a few thousand miles on it had almost zero hydrocarbons. This last one with 120,000 miles had absolutely zero hydrocarbons. While that's not the only pollutant we're concerned with, show me a coal burning power plant that puts out that low of emissions for a given power output. Ethanol mix in the fuel is not needed nor is it good for the car or the environment. If they actually cared about mpg they would have left the gasoline's octane the same and let the car manufacturers take advantage of the 95-96 octane with more ignition timing to get back some of the losses.
Another problem with ethanol is it can cause the car to run leaner. The ECU has a target AFR to hit under various conditions and it uses the 02 sensors to make sure it's hitting that target. Introduce the ethanol mix without changing the target and you end up with a lean condition...... Say it's shooting for 14.7:1, stoich for gasoline and it hits the target AFR as it should. The ECU and 02 sensors are doing their job just fine. The problem is, 14.7 is very lean for ethanol. With only a 10% mix the car still runs and it runs acceptable but it most definitely is not going to run at it's best.
I'm going off topic but I believe diesel is the best thing we currently have, at least in the near future. Emissions are now low. They no longer sound like a diesel or smell like a diesel or have NVH like a diesel. My friend's Jetta TDI gets 44mpg in town and that's not driving it easy. He's hit 59-60mpg on the freeway a couple times driving it nicely. No batteries and no coal burning power plants to supply the power.
i hate cars starts to ramble, but losiglow and the beginning of IHC's rant is what is important
Old Apr 28, 2014 | 06:49 PM
nfnsquared's Avatar
Re: ^^^^
...From a chemical standpoint, etOH contains only a fraction of the energy that is found is gasoline....
Uh, not correct... Please don't blindly repost crap. Thank you
Per unit volume, pure ethanol has about 2/3 of the energy of gasoline, or 66.7%.
Therefore, via simply chemistry, you're going to suffer an equal mileage loss equivilant to the reduced energy potential from added etOH. Usually it's less than 10% since etOH contains some energy (just not nearly as much as gasoline)...
It is indeed less than 10%. The total energy in E10 is 96.7% of straight gasoline, assuming that the E10 in question does indeed have a full 10% ethanol. E10 only means "up to 10% ethanol". The exact content of ethanol in E10 varies, so not all E10 (if any) has a full 10% ethanol.
So, worst case (and assuming you are filling up with a full 10% E10 variety), mileage should suffer by 3.3%, or on our TLs, about 1 MPG.
In practice, I haven't been able to see that at all. I've been running E10 for at least 4-5 years up here in ND and I still get above EPA estimates for highway driving (30-31 MPG).
Old Apr 28, 2014 | 06:58 PM
I'm not trippin either.
I get 21-22mpg in pure city with lots of stomping on the skinny pedal with up to 10% ethanol fuel.
I'm sure if i got on the freeway at a constant 60-65mph I'd able to get up to 30mpg.
in other words, E10 is all I know. I've never had fuel without it
Old Apr 28, 2014 | 07:47 PM
swoosh's Avatar
takin care of Business in
I like nfn
Old Apr 29, 2014 | 08:52 AM
98vtec's Avatar
just fyi, 14.7:1 is not "very lean" for ethanol. The parts air vs fuel can be tuned the same as straight gasoline. Just because their stoichometric ratio is larger, doesnt mean it gets tuned different. It only means more fuel is used to obtain X AFR vs gasoline.
I have never tuned straight gasoline before though so I cannot comment on gasoline and e10 but i can bet there is a very low difference in injector pulsewidth.
I'm looking forward to tuning my TL and MDX once KTuner releases the reflash package for them.
Old Apr 29, 2014 | 08:54 AM
Nick216's Avatar
The Boss
Someone said shell v-power is no ethanol. Not sure if i believe it.
Old Apr 29, 2014 | 09:00 AM
bla8291's Avatar
"...From a chemical standpoint, etOH contains only a fraction of the energy that is found is gasoline...."
Re: ^^^^
Which is still a fraction.
Old Apr 29, 2014 | 09:02 AM
Do you know what blanket statements are?
how about the word, 'gullible'?
Old Apr 29, 2014 | 09:06 AM
Nick216's Avatar
The Boss
Woah woah. I seen a thread labeled ethanol. It was my chance to see if v-power is actually pure gas.
Old Apr 29, 2014 | 09:08 AM
Wow, that's some awesome fuel economy. I get an average of 20, and about 17 or 18 if I drive liberally.
Old Apr 29, 2014 | 09:09 AM
Old Apr 29, 2014 | 09:10 AM
I used to average about 19-20 in the city...
until, i bought light weight rims
Old Apr 29, 2014 | 09:20 AM
xdmds's Avatar
I'm lucky enough to have an ethanol free 91 station right next to my school campus. I've never gone back to E10 since.
Old Apr 29, 2014 | 04:06 PM
losiglow's Avatar
Beat me to it. I'll admit, I didn't know the exact number but it's fact that it's less than gas.
Old Apr 30, 2014 | 10:35 AM
alexb92's Avatar
Old Apr 30, 2014 | 10:03 PM
Jesse729's Avatar
I am not sure what the purpose of this discussion is. There is up to 10% ethanol in the gas at 99% of gas stations it is unavoidable to almost everyone.
Old May 1, 2014 | 05:43 AM
YeuEmMaiMai's Avatar
ethanol will break down and leave a green film all over your fuel system within a matter of months. I avoid it like the plague when it comes to my scooter as even when I run the machine dry there is still just enough left to cause problems. I really dislike taking scooter apart once every 2 years to clean the green crap out of the carb...
Corn is for eating, not burning as fuel....
Old May 1, 2014 | 10:21 AM
Originally Posted by yeuemmaimai
ethanol is for drinking, not burning as fuel....
ftfy
Old May 1, 2014 | 10:47 AM
Old May 1, 2014 | 10:53 AM
ez12a's Avatar
the overexplainer
at least on my bike running it "dry" doesnt get all the fuel out. Some could be still stuck in the float bowls and in the crevices of the tank.
best bet for long term storage is to either drain the carbs and tank manually or fill it up to the top, put marine stabil in it, and ride it around to circulate the treated fuel.
98vtec's Avatar
i have never encountered this but i typically use anything that has gas in it. Honestly, the only problem i see ethanol having is when the fuel is left immobile in the fuel system or engine for long periods of time. but like any fuel product, it will begin to break down eventually if left alone.
you can add fuel stabilizer to gas tanks if you plan on leaving it sitting for a bit and it will help keep it from breaking down and gumming up the carb jets and bowl.
I run a fuel cutoff switch on my lawnmower. when i am done, i shut the valve and let the engine run itself out of gas which only takes a few minutes of idling.
Old May 1, 2014 | 08:41 PM
NvrDwn's Avatar
There are a bunch of stations around here, but they are over 4 a gallon for the good stuff
Old May 1, 2014 | 09:04 PM
ez12a's Avatar
the overexplainer
come to socal, where everything is above 4 lol
San Yasin
Sep 29, 2015 10:52 AM
gavriil
Nov 12, 2013 10:57 AM
gavriil
Apr 19, 2006 09:02 PM
SpeedyV6
Jul 28, 2005 12:23 PM
