Engine Running Lean please help!
Old Mar 9, 2025 | 04:30 PM
KanPhatty's Avatar
8th Gear
Hello, I have a 2007 TL Type S. I'm currently having trouble figuring out why the car is running lean. I performed a vacuum smoke test and noticed the EGR valve letting smoke out. I replaced that and no luck. I have read some threads on here saying that this could be caused by the valves needing a adjustment. I did a data log for the car maybe someone experianced could take a look at it and give there two cents before I keep throwing parts at this car... Thank you guys in advance!
Old Mar 10, 2025 | 07:09 AM
KanPhatty's Avatar
8th Gear
Here is a picture of the live data as well.
Old Mar 27, 2025 | 11:40 PM
Chad05TL's Avatar
No codes? CEL?
Old Mar 28, 2025 | 04:08 AM
KanPhatty's Avatar
8th Gear
Hi Chad thank you so much for responding. The car did have a CEL light but I had to disconnect the battery to work on it and the light cleared. It was throwing P0171 and P0174 but ever since the reset it has not thrown them.
Old Apr 1, 2025 | 03:36 PM
Chad05TL's Avatar
the 430 may be a result of the lean condition. Have you ever been inside the motor? Have you ever cleaned the fuel injectors?
Old Apr 15, 2025 | 06:57 AM
KanPhatty's Avatar
8th Gear
Hi Chad, I ended up taking it to the mechanic. They did a valve adjustment and reprogramed the ecu. They put new gaskets on everything and car is running normal now!
Old Apr 15, 2025 | 07:17 AM
Chad05TL's Avatar
Sounds good
Old Apr 15, 2025 | 10:38 AM
Chad05TL's Avatar
How many miles are on your car?
Old Apr 15, 2025 | 10:46 AM
KanPhatty's Avatar
8th Gear
On the body about 199k and engine around 70-80k had a new motor put in it that came from jdmnewyork
Old Apr 15, 2025 | 10:52 AM
Chad05TL's Avatar
I wonder if they were truthful about the miles... Because these cars do not really burn lean at 70 to 80,000 miles because it needs a valve adjustment.. and I've never heard of a reprogramming at the stock level, that changes the way it burns fuel. That's only for aftermarket v8's who change their cams and stuff. =)
Old Apr 15, 2025 | 11:00 AM
KanPhatty's Avatar
8th Gear
I wouldn’t be surprised if they lied about mileage, but this engine works a lot better than a hydro locked one . I correct myself it was a sensor/module relearn. They also replaced pcv valve
Old Apr 15, 2025 | 11:02 AM
Chad05TL's Avatar
Which sensor?
Old Apr 15, 2025 | 11:04 AM
KanPhatty's Avatar
8th Gear
Good question…I guess I should ask more questions next time
Old Apr 15, 2025 | 11:26 AM
KanPhatty's Avatar
8th Gear
I will upload another reading once I get the chance. Again i appreciate your help a lot Chad. Thank you!
MrVtech
Dec 30, 2020 08:00 PM
zombiegumball69
Dec 24, 2014 10:23 AM
Keran
Apr 2, 2008 09:03 PM
Keran
Apr 2, 2008 07:22 PM
Acura3.0CL
1G CL Problems & Fixes
Mar 14, 2006 01:19 AM
