Engine paint failure
So I am too embarassed to post pics, but i decided to take a can of white spray paint to my WDP TL. It doesn't look that good and I need to order new panels to replace the spray painted ones. I need to confirm that I am ordering the right parts-
please check me on the following-
-Right side battery cover
Part # 005 31531-SEP-A00 COVER, BATTERY 001 2004 TL 17.05 12.79
http://www.acuraoemparts.com/delray/...All&vinsrch=no
-Top right above battery
Part # 74226-SEP-A00 EXTENSION, COWL TOP DRIVER 001 2004 TL 23.63 17.72
Bottom left covering windshield spray-
Part # 002 74119-SEP-A02 GARNISH, R. DAMPER HOUSE 001 2004 TL 24.25 18.19
Same site as above
Top left above windshield washer
Part # Qty:
003 74225-SEP-A02 EXTENSION, COWL TOP PASSENGER 001 2004 TL 26.58 19.94
Same site as above.
Am I correct? Thanks
Same site as above
Part # Qty:
Same site as above.
You are correct.
You gotta have more faith in yourself - I think it's quite clear which part is which haha.
/thread
/thread
AZ Community Team
Received 7,771 Likes
You should post pics. Seriously.
It might look like shit, but it might still be fairly easy to fix. Some sanding and additional prep, etc., and you might be ready to re-spray.
Try taking a heat gun or a good hair dryer to the panels .. you will be suprised .. sometimes the paint will lift right off ...yes including engine or caliper paint .. the plastic & paint expand at different rates .. I have done it on the Tl and Passat engine covers.
The following 2 users liked this post by justnspace:
ABP_04TL (01-06-2012),
SharksBreath (01-04-2012)
Stripping paint off of plastic is easy. Just get some 91% rubbing alcohol and soak the panels in it. It won't hurt the plastic and after a few hours the paint will just wash off with water. It's an old car modeling trick that has worked every time for me. A bottle of the stuff will only cost about $1. If you go that route pick up a few bottles though.
Okay so I went out and bought mineral spirits. 3 gallons. 20 bucks.
I put them in a bucket soaking in it yesterday. It has been 24 hours and the paint isnt really peeling off, but i can scratch it off. So i guess it is working.
Does anyone think that rubbing alcohol will work better than this?
Oh and i almost forgot...
![](http://i972.photobucket.com/albums/ae207/jonboy10/IMAG0310.jpg)
yeah yeah yeah everyone point and laugh...
Mineral spirits is the wrong solvent for that paint .. Prepsol would be more suitable ... but did you try a heat gun or a hot hair dryer like I suggested?
AZ Community Team
Nice golf club. 3-Iron?
A prop is about all mine is good for too.
takin care of Business in
Received 4,732 Likes
thats doesnt look too bad....
i popped the plastics off and kept the engine bare naked....and painted on the manifold and the runners
Phmbm12
i thought it'd be way worse. i was hoping for a disaster. you can easily sand that down and respray it. brought my hopes up for nothing lol.. my first attempt was wayyy worse than that.
Putter actually.
I thought about buying new props, but the old basement putter works way too damn good!
![Sorry](https://acurazine.com/forums/images/smilies/sorry.gif)
Maybe in 10 years our cars will be like the 90's civics of today and people will take spray paint to every panel on the car. That would be my idea of disaster.
Explain. Has anyone else used this?
I have stripped parts before with this stuff, but only metal parts. Standard "aircraft paint stripper" will most likely damage most plastics. In general plastics are more difficult to paint properly, and strip properly. Most paint stripper brands have a special stripper for plastic parts. I know Klean-Strip brand has one in a spray can.
On plastics with poor adhesion, I've used high CFM compressed air to blow away flaking paint. Also if you do a google search, you should find some good methods to remove the paint on plastics.
^^^ I would listen to Nexon....he is a genius when comes to paint and body work....
rockyboy
08-04-2024 10:35 AM
2008, 31531sepa000, 74119sepa0, 74119sepa02, acura, cover, damper, engine, garnish, house, paint, tl, white
